#141 | |
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Infinity (07-09-2019) |
#142 |
Drives: 15BRZ
SS1 coilovers
Can you use the stock sway bar links on the front with these coilovers?
| The Following User Says Thank You to KevBRZ For This Useful Post: | bhmax (08-11-2019) |
#143 |
Drives: 13 BRZ, 17 Focus RS
#144 |
Drives: 15BRZ
My stock endlinks are a mess anyhow, rusted to hell and back and i ended up stripping the allen end so i am probably gonna have to get a set of aftermarket ones anyhow lol There was so much rust even after spraying and using a wire brush i could still barely get the allen in there.
| The Following User Says Thank You to KevBRZ For This Useful Post: | bhmax (08-13-2019) |
#145 |
Drives: 2013 FR-S Series 10
#147 |
Drives: 2017 BRZ Perf. Pkg.
I've been running track days all summer and I'm very happy with the RCE SS-1. It can pass the wife test on public roads, and still put down a hot lap at the track.
| The Following 2 Users Say Thank You to femaledog For This Useful Post: | kevaughan (09-15-2023), Racecomp Engineering (08-16-2019) |
#148 |
Drives: brother from another mother
@Racecomp Engineering
Got a set of these over a month ago but haven't quite gotten around to installing them just yet. I noticed this recommendation in the instructions and had a quick question about it... "4.It is imperative that you do not damage the piston rod surface, through the use of pliers, etc. as even the smallest damage can result in seal damage, and will not be covered under warranty.A strap wrench is highly recommended to prevent the strut shaft from spinning. Wrap the strap wrench around the strut shaft twice for best results." I'm sure I can get a strap wrench for this but I don't feel like buying one just to use it once. Is it absolutely mandatory to use one or is there another method I can use to install correctly? I assume this is to keep the rear strut pistons in place while installing the double tophat nuts to 15ft. lbs? Last edited by Velisma; 08-18-2019 at 01:59 PM. |
#149 |
Drives: 2023 BRZ
This is a common problem. I broke two strap wrenches trying to hold the shaft without damaging it. Instead, give the top nut four or five quick pulses with an air gun. This will minimize the shaft spinning, yet still tighten the nut.
Director of Rocky Mountain 86CUP
| The Following User Says Thank You to Pat For This Useful Post: | strat61caster (08-18-2019) |
#150 |
Drives: 2014 GT86
Yeah, that is also common hack around i've seen suggested for other coilovers aswell. For exmple, here.
| The Following User Says Thank You to churchx For This Useful Post: | ChRZ (11-30-2019) |
#151 | |
Yeah, I figured as much. The thought passed through my mind to use my impact but I guess I was worried that it might possibly strip due to how thin the bolt is/what little threading it has and not sure how soft the metal is. Alright, simple enough. I'll give that a try. Thanks! |
#152 |
Drives: Take a guess...
I have a Perrin 22mm front bar paired with the SS-1s. I re-used some Whiteline KLC 180-195 end links, which were quiet for the first 1,000 miles and two autocrosses on old street tires. The springs must have taken a set, however, because the bar started contacting the body/pinch weld in the middle of a road trip.
What's Racecomp's recommendation for adjustable end links? I figured I would ask since it takes a bit of time to get the end links set up and clearanced properly. |
#153 | |
Drives: 15BRZ
re end links
#154 | |
Drives: '13 FRS - STX
I lost a nut on an endlink, drove the car for three weeks (two autox events) before noticing when I swapped wheels and tires, totally explained the odd turn in behavior, I hit a few cones those events...
| SuperStreet ToyoTires Meals N' Wheels Meet at Edgie's in Milpitas - photos & videos | PMok | Northern California | 5 | 02-09-2015 05:26 AM |
| -0.5 for RaceComp Engineering | wrxneffect | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-04-2014 04:21 PM |
| Mackin FR-S Superstreet Cover Evasive Tuned! Out Now!!! | Evasive Motorsports | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 18 | 12-07-2013 10:20 PM |
| Racecomp Engineering | industrial | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 05-02-2013 04:17 PM |
| Racecomp website down? | Mikepage | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 04-22-2013 03:12 PM |
