#43 |
Drives: Q5 + BRZ + M796
If you don’t have E85, or if you will primarily be on pump, even at 93, I would lower compression. Even if you do it moderately to 11-11.5:1 then it would be good. If you plan on tracking the car then definitely. I feel like a turbo could hit that power easier than a SC, so maybe stock compression on a turbo setup for street use only would be fine, as long as you never want too much more power. Reducing the compression would make it significantly easier to make more power or safer power on pump.
| Whats my car worth? (Built engine, Turbo kit) | glorydays | FR-S / BRZ vs.... | 16 | 07-13-2019 08:55 AM |
| Built FI engine on 100 RON | Boris_Petrov | Engine, Exhaust, Transmission | 9 | 03-10-2019 04:55 AM |
| Fully built engine with big turbo in dubai TARGET 550WHP | SUB-ZERO | Forced Induction | 84 | 12-01-2014 12:34 AM |
| 9 SEC -PRECISION 6466 SUB-ZERO MOTORS FT86 CUSTOM TURBO KIT , ENGINE BUILT 600WHP+ | SUB-ZERO | Forced Induction | 44 | 07-09-2014 09:44 PM |
| What is the best turbo for a fully built engine scion frs | SUB-ZERO | Forced Induction | 41 | 09-18-2013 06:41 PM |
