Drives: 2017 Halo 86
How are these drop range measurements to be interpreted?
New coilovers came in with actual specs, which I greatly appreciate as my last set did not. As I have been suffering from about a year with terrible ride quality of the previous, I am looking to doing things right this time around with prep and installation.
So, I'm scratching my head looking at lines in the manual that read: Dimensional Data and Ride Height (for Front) Long Bracket Set Recommended height (mm) | 10 Normal Drop Range (mm) | -25 ~ -30 Bracket Length adjustment range (mm) | +5 ~ -40 Normal range from factory (mm) | +15 ~ -40 Being as I cannot physically take a ruler and take a negative measurement without crossing into an alternative dimension (jokingly), how should these numbers be interpreted?
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
#2 |
Those just look like ranges of how you can set the ride height compared to stock... what coilovers are they?
#3 | |
RS*R Sport i's just came in. Still in the low-end (just under $2K) but these are going to be a huge upgrade from what I'm coming from. I'm SUPER excited to get these suckers on.
#4 | |
Drives: 2019 Toyota 86 TRD SE
Just got RS*R down springs myself. Please let me know how their coilovers ride! Sent from my iPhone using Tapatalk |
#5 |
Drives: '13 FRS - STX
They are measurements on the shock assembly for where to adjust the cartridge in the end fitting, if there's no diagram in the instructions showing what they're measuring maybe email their support.
The negative and positive probably refer to raising and lowering respectively and are based off the factory set height of the dampers as they come out of the box. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Lakitu (08-15-2019) |
| KW V3 suspension measurements for warranty. | mkivalex | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-07-2016 12:35 PM |
| Can anyone be so kind to get me measurements? | VindiCated | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-13-2014 02:17 AM |
| Bumper stop measurements | Sojhinn | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-18-2014 12:29 PM |
| Underbody measurements pls | Mgb_bj70 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-29-2014 06:19 PM |
| Scion FR-S OEM Intake Measurements 56k RUN AWAY! | soros151 | Engine, Exhaust, Transmission | 15 | 10-26-2012 04:39 PM |
