Fuel system ideas?
I'm leaning towards the radium dual pump setup but I'm curious where you guys are mounting your regulators and fuel filters? I'm looking for a clean solution as I will be installing the engine and everything very soon.
#2 |
2 ugga dugga's
Drives: Nike
I am using the radium dual pump. Feed and return lines are easy to install and run thankfully. My radium filter is under the car and my fuel pressure regulator is mounted on the driver side strut area where there was a freed up threaded hole for a 10mm bolt. The hole is just below the 2 factory 86 threaded stud/strut bar mounting points.
Feel free to poke around in my build thread: http://www.ft86club.com/forums/showthread.php?t=126185
The Following User Says Thank You to Clash0901 For This Useful Post: | all4spl (08-13-2019) |
#3 | |
I looked through your whole thread. Any pictures of the lines and the filter under the car by chance? I appreciate it! |
#4 |
2 ugga dugga's
Drives: Nike
I can take some today but mine just run along the bottom where the OEM ones were. And the filter you have to get creative, or there is a company (not sure which, maybe Radium) that makes a special mount for their fuel filters that holds the filter and mounts to the chassis.
#5 | |
#6 |
Drives: 2017 WR BLUE BRZ
I bought the radium filter and mount. Massaged(pounded) the floorboard in under the driver seat to get it up above the lower points of the floor board. Then I made an cover/skid plate for it all with aluminum plate. I ran the fuel lines up into the frame rail and drilled a hole up top to get it into the engine bay.
Can see some of it here https://www.instagram.com/p/Be8FJyjl...=1d1k9brxt2pu8 And here https://www.instagram.com/p/BjD9JOjD...d=gndu6lvnvxvh Supply and return fuel lines enter just under the brake booster. |
The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post: | all4spl (08-16-2019), Sportsguy83 (08-15-2019) |
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System | DeliciousTuning | Software Tuning | 20 | 06-09-2016 06:21 AM |
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap | Toxicmilk45 | Engine, Exhaust, Transmission | 4 | 12-14-2015 03:52 PM |
fuel system. | Reaper | Tracking / Autocross / HPDE / Drifting | 2 | 08-06-2015 10:12 AM |
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! | Dustin@Dynosty | Forced Induction | 4 | 10-08-2014 10:00 AM |
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
