Old 08-12-2019, 10:47 PM   #1
JDMPR725
Drives: 2013 Scion FRS (10-Series)
Hole Behind Rear Scion Badge On Trunk For Toyota Logo Swap
I'm working on swapping out the scion logo badges, 86 piston side badges & the FR-S badge on my 2013 Scion FRS. I ran across a small stopping point when I was able to remove the rear scion badge but found a random hole in the middle of where the badge would be. It's a pre-made hole that I'm guessing its originally designed that way. It could be an access point for a maintenance hole for the trunk mechanism or maybe for a rear-view camera but I could be wrong. I put my new gloss black Toyota badge but the whole still somewhat shows. I was able to cut a small aluminum tape shape to cover it up but I had the wrong touch-up paint pen for the paint.
Has anybody ran across this situation and have done anything to fix it?
JDMPR725 is offline   Reply With Quote
Old 08-13-2019, 07:25 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
You mean the hole(s) that the badge attaches to the trunk with?
See photo #3
http://www.ft86club.com/forums/showthread.php?t=7296
BigTuna is offline   Reply With Quote
Old 08-13-2019, 08:29 AM   #3
JDMPR725
See photo #3
No. Theres an actual hole a bit smaller than a penny the dead center behind the badge. It turns out I did a bit of research and found out that 10 series cars have this because theyre supposed to have a scion badge that lights up and that hole with the cable is the power for it.
Im just figuring out how to patch it and find a way to paint it with the new badges on.
Old 08-13-2019, 10:55 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
the best solution is to get a replacement trunk garnish.
badge, cosmetic modification, frs
Another Toyota Airbag logo swap... jadewbj DIY (Do-It-Yourself) Guides 40 03-08-2014 07:00 PM
BRZ/FRS Trunk Swap - Re-Badge Options? KGFRS86 Cosmetic Modification (Interior/Exterior/Lighting) 8 06-21-2013 02:19 AM
"Toyota" trunk badge and GT86 Trunk badge Juurian Cosmetic Modification (Interior/Exterior/Lighting) 3 04-04-2013 05:30 AM
Need Help Scion Badge Or Toyota Badge? Dragon86 CANADA 3 08-26-2012 12:20 PM
