#1079 |
No. Need I point out that I have repeatedly stated who the Canadians should go to and at least consult with and that agency is NOT Transport Canada. As yet nobody has come forward and said if the proper agency has helped or at least advised them.
I just want to understand what people think will happen by going to CT. There is d1ick all they can or will do to help people who's engine failed after recall work.
#1080 | |
Drives: 2013 brz limited / galaxy blue
I had a similar experience with my Brz overheating after the recall and needing head gaskets blown, been weary of car since I got her back ಠ_ಠ Sent from my iPhone using Tapatalk |
#1081 | |
Drives: 2013 FR-S, 6MT, Daily Driver
CAMVAP? As I've recently stated I called them and had a conversation. They said that despite all circumstances the 2013 model year is not eligible for their program. They suggested other approaches, including another consumer reporter/journalist and small claims court. |
#1082 |
Leery. You have been leery of the car. Although I suppose being constantly leery could make you weary.
#1083 | |
#1084 | |
It's worth to try and get nothing, than not to try at all. At least there's a chance something will come of TC poking at the issue. If Toyota is forced to admit a problem, then they'd be more likely to compensate the affected owners. |
#1085 | |
TC is very specific that they will only identify safety issues to the manufacturers and will not get involved in any other item.
#1086 |
JDM Vaping Stance Nation
Drives: 2013 White
So I don't have the failure thankfully, but I know some people are skeptical of bringing it in for recall.
I'm about 5,000 miles after done my recall and also flashed to OFT Basetune for stock. Will be dropping my oil pan soon to install a turbo. I can take pictures of my screen filter if anyone is interested.
Clueless
#1087 | |
Drives: 13 Scion Frs
#1088 |
When people are saying their cars were repaired under warranty, I'm assuming they mean the recall's warranty right? This isn't due to a separate warranty they purchased right?
#1089 | |
Drives: Toyota Celica
#1090 | |
If you are still under your drivetrain warranty it might make the repair decision easier.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#1091 | |
Drives: 2013 White
Pretty much as soon as I got my notice in the mail I scheduled a service appointment. My local dealership said he had his "top toyota tech" working on my car and they were only doing one car a week, only took 3 days and it was hell for me driving that camry with eco-mode. Everything seemed fine to me when I got it back so I didn't really have a reason to have my oil tested. Then I saw articles and posts about failure rates and I was a bit concerned. Thankfully nothing has happened so far. The oil is still there in my car, just waiting for my new clutch break-in before I install the turbo, new oil and pan to check the screen filter to see if there is that gunk or sludge like in the picture.
Clueless
#1092 | |
Drives: 2017 Subaru BRZ PP WRB
So if the intent is to see if excess sealant was used in the repair and might soon cause engine failure, I believe that a visual inspection of the oil pickup and any passages that you might be able to see would be more useful. This method of course would be more laborious than sending in the used oil sample. |
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 03:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
