Old 08-08-2019, 04:44 PM   #1
Roth_nj
Drives: Brz ts
Open flash stage 1 performance
I have a 2018 ts. I just bought the open flash tablet and flashed the stage 1 tune for 93 gas. The rest of the car is stock besides running 93. No e85 available here.
The car feels super sluggish to me. Especially lower in the rpm range. It feels like it picks up high but not until maybe 6000 rpm.
Is this typical? Did they set up this tune for more top end?
I wasn’t expecting anything magical, but after a month I’m always over the torque dip and wanted to see if this would help in anyway at all. I’m almost debating going back to stock until I can buy headers....
I tried searching but didn’t see much specific as this
Thanks
Roth_nj is offline   Reply With Quote
Old 08-08-2019, 05:04 PM   #2
OwlDance
Drives: Halo 86, '19
Dead pedal/sluggish feeling is reported as normal within a hundred or so miles of the reflash until the ECU relearns throttle/pedal positioning. It's probably that.
FWIW the 2017+ MT cars use a different exhaust and intake and I'm not sure if the stg 1 that comes bundled with the tablet is meant for it. Check open flash's website and see if you can't find one of their tunes for an MT2018 car, I'm pretty sure they have it, it should run better.
OwlDance is offline   Reply With Quote
Old 08-08-2019, 05:52 PM   #3
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Mine is a 2013 manual with a catback. I flashed to stage 1 and I noticed a change. Cold start isn't as loud, stable rpm idle and it was smoother overall.
Clueless
YamahaR86 is offline   Reply With Quote
Old 08-08-2019, 08:00 PM   #4
Frankz54
Drives: 2019 Toyota GT86
I have a 19' GT86. Just flashed to Stage 1 this week and also noticed a bit the same. Lower RPMS feels like the car is being held back or pulling back. I do have the newest version 4.0.3, at Higher RPM car flys and catches speeds of 100+ like nothing. Waiting to install my header to upgrade.
Frankz54 is offline   Reply With Quote
Old 08-08-2019, 08:44 PM   #5
Roth_nj
Drives: Brz ts
Mine didn’t come with any tunes on it and I had to download/put them all on it. I have the ones for the 2018 with manual
Old 08-08-2019, 08:55 PM   #6
OwlDance
Give it around a hundred+ miles and see if it feels better is what I've heard.
The Following User Says Thank You to OwlDance For This Useful Post:
DaBoBo21 (08-11-2019)
Old 08-09-2019, 11:02 PM   #7
steve99
Drives: FT86
The OFT V4 tunes switch to open loop fuel mode very quickly at quite low throttle input. this can tend to make car run quite rich fueling at lower/mid rpm and can dull performance as the open loop fuel table is set quite rich
Ive fixed this for a few guys in Australia
Old 08-10-2019, 11:16 AM   #8
Frankz54
So what do you recommend? Downgrade the version? And is this only with Stage 1? I'm about to flash to Stage 2 soon.
Old 08-10-2019, 06:48 PM   #9
steve99
Drives: FT86
You may want to make changes to the closed loop fuel tables, and the closed loop to open loop timers and throttle triggers and open loop fuel tables. So the transition is smoother and car stays in closed loop longer
Old 08-30-2019, 09:44 PM   #10
InstaGib
Drives: 2015 Scion FR-S || Raven Black
I can't confirm this is the reason (although Steve99 has helped me in the past, and I would absolutely defer to his advice), but I can confirm my car ran rich at low RPM and (at least it felt to me) lost power compared to stock. I was in general not impressed with the stage 1 tune, it felt like the only meaningful change was to be more aggressive with the VVT.
I am much happier with the Stage 2+ tune, although I still feel it's a bit rich on the lower RPM's. From my understanding though, this can vary from car to car and header to header. I plan on doing some tweaking in romraider in the near future. Still far preferable to stage 1 though.
InstaGib is offline   Reply With Quote
SOLD Open Flash Performance Tablet v1 krzybrz Engine, Exhaust, Bolt-Ons 0 06-19-2019 10:46 PM
Car won't move while in gear after open flash stage 1 tune. Krrich18 Software Tuning 13 03-15-2018 04:22 PM
Has anyone ever had an OFT repaired by Open Flash Performance? guybo Software Tuning 10 11-01-2017 06:06 PM
Open Flash Tablet stage 1 or UEL 2? donkeysgt86 Software Tuning 0 12-07-2016 05:24 PM
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 07:29 PM
