#29 |
Drives: fdsgh
Have you tried getting a stage 1 tune or going stage 2 with headers? Like I said in my previous post the headers and tune cured it and I don't have the sound anymore. I am gonna test stage 1 on stock headers and see if its still there.
#30 |
Drives: fdsgh
Okay so I put my stock headers back on and tuned my car with stage 1 tune from delicious tuning, everything else is stock but the tune. The sound is gone completely. I suggest anyone with this noise get a stage 1 tune at least, I am sure OFT would do the trick.
#31 |
Enthusiast 86
Drives: Toyota 86 GT
Hi All,
Well, I never thought id come across the same strange sound that my car makes. A also have a strange metallic flutter noise at low RPM. I used to think it was because of the load I was putting the car under in low gear. It seems more apparent when I have it in 6th gear and running for about 40 mins, tapping the throttle and pushing the engine the problem seems to get worse. I let off the throttle and put it in high gear and the problem goes away. Tap-in-Knock? is that whats its called, I had it at stock and I am now in stage 2 tune with the works and it still comes back now and then. |
#32 |
Drives: manual Toyota 86
I still have this sound guys but much less so since going Catless headers and tune. I have accepted it as a characteristic of the vehicle. My uneducated guess as to why I don't hear it as often now is due to having more torque in that rev band, but every now and again it will do it just rarely.
#33 |
Enthusiast 86
I used to think it was a rod knock, which I was panicking and went to the dealer. The dealer did a full sound sonic check and everything and said they couldn't find anything.
A garage I spoke to said if it was rod knock then it won't just come and go it would stay and get worse, so it sounds like it's, not rod knock. I look into tap-in-knock and see what I find. |
#34 |
Only happy when it rains.
Drives: series.blue
This car sounds like a farm tractor. It absolutely despises any load at all under 2500 rpm. Unless you are triggering codes it is probably not a big deal.
#35 |
Drives: 2013 frs red
I never put my car under load below 3500 rpm. I do most of my driving 3 grand and above
#36 |
Drives: Car
I've had the same issue for the last 40k kms. I recall bringing it up once here and Flanders told me it was the heatshield rattle.
It is apparent for me when I accelerate at around 3k RPM 5th or 6th for about an instant when I go on the gas. |
| The Following User Says Thank You to 8inchAzN For This Useful Post: | Lantanafrs2 (08-12-2019) |
#37 |
Drives: fdsgh
The sound came back for me. I didn't hear it stage 2 catless, went back to stock, started hearing it, went stage 1, stopped hearing it but I am now stage 1 for around a month and I am hearing the sound again. It isn't as frequent as fully stock, but its now coming and going.
I was searching other threads about this and it seems like some folks are saying it has to do with the transient ignition retard table, which I know nothing about. Anyone know anything about that? I am a huge perfectionist and this sound really bothers me , I know these vehicles sound like tractors half the time but this specific sound irks me somehow.http://www.ft86club.com/forums/showt...=123720&page=3 |
#38 | |
Was searching for TIR related threads and found this one. Listening to the video in this thread and for sure it's tip in knock. I tried to capture this sound with a microphone on my car, but it didn't come out as well as this video. I don't know what year everyone in this thread has but this issue was mostly solved on the 2017 and newer TIR tables. I have a 2013 which did this really bad but the 2017 TIR table solved it but also caused the car to randomly ignore blips which was crazy annoying. I tried to come up with my own TIR table to avoid the tip in knock but not kill throttle response and never really got it right. Today I run the 2013 table but with E85 and the tip in knock is gone and my throttle response is really good. With enough patience and a lot of trail and error I think you could come up with a good compromise without switching to E85. |
| The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (12-18-2020) |
| Weird sound over 60mph | FRiSson | Issues | Warranty | Recalls / TSB | 23 | 03-05-2018 11:47 AM |
| Brief Scratching/squeal sound. Accelerating/change gears. | resli | Issues | Warranty | Recalls / TSB | 13 | 03-02-2016 12:56 AM |
| metallic sound coming from engine when accelerating! | jaorocks1 | Issues | Warranty | Recalls / TSB | 4 | 05-02-2015 10:32 PM |
| question regarding screeching sound when accelerating | kudougw | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 07-18-2014 03:37 PM |
| This might sound weird | mrha | BRZ First-Gen (2012+) — General Topics | 10 | 10-06-2012 06:06 AM |
