Old 08-08-2019, 04:52 PM   #155
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Me too, I have no E85 access So if the Beta testing can confirm similar power gains this would be a nice part to try.
I have e85 access but the difference for value is not that big at the moment. ~$.40 cent difference between 91 and e85. Car is DD and I rather have miles at the moment than fun since I commute 20+ miles a day. It's either 200 miles to the tank w/ e85 or 300 with 91.
If the power gains are good, then it's something I might consider as well but without a proper tune we can't fully judge.
Originally Posted by Lantanafrs2 View Post
The problem will be acquiring an ots tune. Shivs moving away from this platform and ecutek will be expensive.
True but it doesn't mean that we don't have any other contributors that can possibly make a generic safe OTS tune for it. It just takes a bit more time to do so.
Bach415 is offline   Reply With Quote
The Following User Says Thank You to Bach415 For This Useful Post:
Lantanafrs2 (08-08-2019)
Old 08-09-2019, 05:33 AM   #156
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by PulsarBeeerz View Post
Looks like its with a full exhaust. They used a Tomei UEL header and over pipe and what appears to be a Q300? catback and a catless midpipe from what was posted on IG. They need the help of Steve99 or Wayno to tune if they wish to stick with OFT. Everyone else shows results after a custom tune so its totally fair play.
I think the point is to use a simple tune anyone can grab. We all know Everyone can make more power with ECutek and a good tune. It is better this way because the results are more real world for everyone. I mean they could use an Ace header and all the best tack on aftermarket goodies to make their product look better too.
why? is offline   Reply With Quote
Old 08-09-2019, 11:21 AM   #157
PulsarBeeerz
Drives: JRSC BRZ SOLD
No they used what they had available since OFT wasn't interested in helping develop a tune when they reached out to them.
PulsarBeeerz is offline   Reply With Quote
Old 08-09-2019, 11:45 AM   #158
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Sorry this is def off the topic, but how do you get 300 miles a tank? I get 190 miles on 92 gas
Sent from my SAMSUNG-SM-G935A using Tapatalk
Jajanken86 is offline   Reply With Quote
Old 08-09-2019, 11:51 AM   #159
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't think it would be too hard to tweak a base OTS to the manifold, a lot of us have to do that anyway. My car would not run close to right with an OTS tune, LTFT was around -10%.
I know one of the beta testing requests was the car be dyno'd without the tune tweaked. That will be a good baseline to see how much benefit we can potentially see with just using an OTS tune vs currently posted gains.
@Jajanken86 I usually fill up at 11 gallons and get around 28-32mpg. If you are only getting 190 to a tank, that is just 17mpg.
Old 08-09-2019, 02:06 PM   #160
Lantanafrs2
Drives: 2013 frs red
After using e85 for 2 years, I wouldn't want to drive the car on 93. I'm getting 21 mpg
Lantanafrs2 is offline   Reply With Quote
Old 08-09-2019, 02:37 PM   #161
Bach415
Bach415's Avatar
Not too sure honestly. Probably the way I drive since it's been that way when I got the car early 13. I don't have a heavy foot. My old commute was 100% city driving and I averaged around 260-270 a tank at that time. My current commute is 90% city (~25mpg), 10% freeway(~32-35mpg). Averaging around 26-28mpg. Usually fill up about 11 gallons every time.
Not sure if my mods did anything to help it (despite threads saying it helps a bit) but listed below are my aero/tune mods.
Car mods prior - Velox/Verus front splitter, Nur spec front lip, Tomei type-80/80r catback, air filter, no tune.
Car mods at this current time - OFT Stage 1, air filter. Velox/Verus diffuser.
We can take this further in a different thread or thru pm if you like so we don't derail this thread like prior to the cleanup.
Old 08-22-2019, 10:19 PM   #162
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Has anyone purchased one yet?
Dr. BRZ is offline   Reply With Quote
Old 08-22-2019, 10:54 PM   #163
Lantanafrs2
Thought you'd be the first?
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Dr. BRZ (08-23-2019)
Old 08-23-2019, 12:58 AM   #164
Dr. BRZ
Dr. BRZ's Avatar
I didn't get picked for the beta testing!
Argh........ So I guess I'll have to be the Guinea pig! Lol
Old 08-24-2019, 11:42 AM   #165
Lantanafrs2
I think the fact that there are gains anywhere with this im is impressive, especially when considering past failed attempts. We're all just hoping a custom tune might make the graph look a bit better but really there are too many exhaust combos out there for an ots tune to be feasible
Old 08-24-2019, 11:52 AM   #166
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't think it is too bad. I am not sure why everyone is so obsessed with low end power. This motor is really knocky at 3k rpm and under. As long as it pulls from 4k and up I am happy
Turdinator (08-25-2019)
Old 08-24-2019, 12:11 PM   #167
PulsarBeeerz
Dirty overlay but..93 vs FBO 85. Not a bad result without custom tuning on a custom IM.
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
NoHaveMSG (08-24-2019)
Old 08-24-2019, 12:34 PM   #168
Lantanafrs2
That's a good point. Low end torque equals instant gratification but this is the wrong car for that
Racer X Fabrication air intake design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 45 08-01-2019 12:29 PM
FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox FT-86 SpeedFactory Engine, Exhaust, Transmission 712 12-11-2018 10:13 PM
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 10:40 AM
Project BRZ Intake Manifold Development TurboBRZ Engine, Exhaust, Transmission 27 08-05-2015 07:44 PM
Racer X Fabrication oil pan design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 87 06-03-2015 11:10 AM
