Old 08-06-2019, 02:21 PM   #5069
Lonewolf
Lonewolf's Avatar
Drives: Moped
It looks like you guys may need some hood vents to help evacuate the engine bay heat...
Old 08-06-2019, 03:46 PM   #5070
peaches
Drives: '14 BRZ Limited
I want some, I just ran out of money. Maybe for x-mas
peaches is offline   Reply With Quote
Old 08-06-2019, 03:52 PM   #5071
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Originally Posted by peaches View Post
When I was NA I had a stock radiator and a Perrin oil cooler, tracks temps hovered in the 260 range so from my point of view, those temps while FI are not that bad.
Now I have the JR dual cooler, will be on track Labor Day weekend so we'll see how that goes.
When I was NA, I had oil temps at around 220. The JR cooler is a beast!
I guess I didn't expect it to jump as much as it did, to the point where it isn't safe to run in hot weather as currently setup.
mistople is offline   Reply With Quote
Old 08-06-2019, 04:34 PM   #5072
CSG Mike
CSG Mike's Avatar
Originally Posted by steved View Post
Setup:
2013 FRS
JRSC factory tune
JR dual radiator/oil cooler kit
Stock bumper/etc
OEM coolant (new)
Mobile1 5w30
Constraints:
No availability of E85
First time running JRSC at the track yesterday at Mission raceway near Vancouver. If anyone is familiar with the track its very tight and pretty short, front straight top speed with my setup was about 145km/h, and there are 3 straight sections. Track is known for being really hard on brakes, so you can probably imagine lots of running out the gears in 2/3 between the corners which means a lot of engine heat.
I threw a CEL after about 4 laps when ambient temperature was 29C (84F), coolant temperature sensor low voltage. My coolant temperature was pushing 250F+, and my oil temperature was pushing 270F. In follow up sessions I could get in 2 laps pushing pretty hard before oil temps would get closer to 260, and I'd have to manage heat by short shifting and not running WOT. Bit of a bummer to be honest.
Last session of the day I turned the heat on full and vented it out the passenger side, and my coolant temp didn't go above 240. I was able to run a full session like that, but I'm obviously uncomfortable with this amount of heat.
As an observation; a new Civic type R was also having heat issues, but that's nothing new. None of the other factory turbo'd cars at the track were doing limpy laps other than an STI.
I *thought* the dual radiator kit would work well but I'm wondering if it was a mistake to purchase it instead of the standalone oil cooler.
I'm looking for any ideas on how to reduce engine oil and coolant temps. I've thought about:
- venting the hood, but I'm trying to keep the car pretty low key exterior wise, and I'm doubtful it would make a big enough difference to be worth it
- changing coolant
- switching to a JR standalone oil cooler
- wrapping the stock header, not sure if this is even possible? I haven't looked at it yet, but usually oem headers don't have a lot of clearance for wrapping. I still have the oem heatshield so it would have to come off - not sure what decrease in temp I'd get
Overall I feel that there likely isn't one solution here and its probably going to be a combination of multiple fixes to get the temperature down, I'd also like some feedback if I'm going to put a ton of effort/time/money into trying to solve this issue and it might not actually be solvable.
Make sure all your factory ducting is trimmed around the FMIC piping and back in place. Also make sure the factory foam was replaced onto your JR DROC.
Hood vents will DRAMATICALLY increase cooling.
As an example, my 360whp turbo car on a stock radiator doesnt overheat in significantly higher ambient temps, with just TrackSpec hood vents.
https://www.counterspacegarage.com/t...s-brz-frs-gt86
Old 08-06-2019, 04:35 PM   #5073
CSG Mike
CSG Mike's Avatar
Originally Posted by mistople View Post
I'm also dealing with very high oil and coolant temps. I'm running the dedicated JR oil cooler with the setup integrated with the intercooler and rotrex cooler.
I saw 262F oil temps during a similarly hot track day this weekend. Really frustrating as I though I'd be rock solid in terms of heat management.
Make sure those OEM trim pieces are in place next to the FMIC. Without them, you're losing nearly half your airflow through the radiator and cooling stack.
Air goes the path of least resistance.
Old 08-06-2019, 04:42 PM   #5074
WC-BRZ
Drives: Black BRZ
Setup:
2013 FRS
JRSC factory tune
Stock bumper/etc
OEM coolant (new)
Mobile1 5w30
Constraints:
E85 is available at Northside Petroleum in New West.
WC-BRZ is offline   Reply With Quote
Old 08-06-2019, 06:12 PM   #5075
steved
Drives: 2013 FRS
Ok that's true, I should have said not easily available
steved is offline   Reply With Quote
Old 08-06-2019, 06:19 PM   #5076
steved
Drives: 2013 FRS
Thats a good point, I'll check the foam bits tonight I have a feeling its still sitting on the top of my old rad :/
Old 08-07-2019, 12:41 AM   #5077
mistople
mistople's Avatar
I don't recall this step in the install manual, but it makes sense. IIRC they would need to be trimmed to fit around the L/R FMIC pipes?
Time to rip off the bumper again
Old 08-07-2019, 12:43 AM   #5078
CSG Mike
CSG Mike's Avatar
It's only mentioned. You can also replace with anything that closes off the area!
Old 08-07-2019, 12:49 AM   #5079
mistople
mistople's Avatar
Cool, I'll try that.
Will this help oil temps as well? How about hood vents? I get that both help with coolant, but I'd love to never see 262F for oil pop up on my AiM ever again!
Old 08-07-2019, 03:28 AM   #5080
CSG Mike
CSG Mike's Avatar
You're on a DROC? Then yes!
Old 08-07-2019, 10:19 AM   #5081
mistople
mistople's Avatar
I have the track oil cooler mounted alongside the rotrex cooler.
Old 08-07-2019, 01:23 PM   #5082
CSG Mike
CSG Mike's Avatar
Then also yes, but to a lesser degree. However, your setup has more cooling for the oil than the DROC.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
