#3655 | |
They will be back in stock soooooon.- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | rustymuffler (08-05-2019) |
#3656 |
#3657 |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | rustymuffler (08-06-2019) |
#3658 |
Drives: 2019 Toyota 86 TRD SE
Hey guys, just wondering if I'm going to need a camber kit for a 1 inch drop on lowering springs? I'm I going to be way out of spec?
#3659 |
Drives: 2015 BRZ
There is no way to really answer that. It all depends on how OCD you are about your alignment. On a 1" drop the fronts isnt gonna be affected much, but the rears will gain some natural camber from lowering. Some people have gotten away without camber kits and some people needed them. For example after lowering you could get -1.6 and -2.0 in the rear if that bothers you and you want it to be even you will need rear control arms.
#3660 | |
Drives: 2022 GR86
From an email discussion with CSG, "At a 1 inch drop with [coilovers], you'll have a natural rear camber of approxmately -2.1 degrees; this is totally acceptable and will not need rear lower control arms." Whereas the extra negative camber in the front is only going to be useful, unless for some weird reason you want zero front camber (which is the manufacturer's spec btw). See also https://www.ft86motorsports.com/wheelitfit/ for some estimates on how much natural camber you'll get with different amounts of drop. |
#3661 | |
Country Boy 4 Life
I LIKE TIRES! |
#3662 |
Drives: 2022 GR86
CSG:
What's the best place to reference for torque specs on bolts/parts that are 2017+ only? e.g. Performance Package Brembo brakes, red intake manifold, etc. |
#3663 | |
Drives: 2022 GR86
I do however agree that the front camber changes due to lowering the car will be minimal. -0.3º for a 1" drop, according to that calculator. |
#3664 |
#3665 |
Drives: 2022 GR86
#3666 |
Drives: ft86
does whiteline w63414 fit on the spc 67655
#3667 |
Drives: 2013 FR-S Ultramarine
Sorry if this has been asked already...
How do you set height on the RCE Tarmac 2? To me it looks like height is set by spring preload. Is there a way to set the ride height independent of preload? Thanks! |
#3668 | |
For reference, our T2s have more than 1.5 inches more total front stroke than a BC ER coilover. That's huge. - Andrew |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
