Old 08-03-2019, 08:29 PM   #183
jflogerzi
jflogerzi's Avatar
Originally Posted by mistople View Post
I clocked in a personal best of 2:00.18 today at The Ridge in the still-incredibly-warm first session before running into car issues The track was also incredibly hot today, so things were a bit greasy even in the early morning.
After lunch I lost a lot power over the course of a session—it almost felt like I was running with no boost given that the car wasn't pulling hard at all. Typically I'll run 128mph by the end of the straight at RMP, but I was topping out at 115mph before hitting the quiet pedal. Not good.
I pulled in tried to diagnose the issue but couldn't see anything out of the ordinary. It could be a combination of heat soak and a not-quite-sorted DT tune.
I also saw oil temps peak at 262F today. Not sure what to do about it yet. I was really hoping to NOT have to buy a vented hood or cut up my own. While I was NA, the JR cooler kept them at a cool 230. I guess it comes with the supercharged territory!
The JRSC is great, but I'm finding myself missing the simplicity of NA today.
On a more positive note, the RE71Rs are awesome! I didn't find the absolute limit of the tires today, however. I could definitely feel them overheat after a few hot laps as everyone says they do. It was so nice to just be able to dig into corners and have the front stick rather than wash out. I can see how it would be hard to go back to the typical street tire selection! I ran them 32psi hot which seemed to work.
Hopefully I can get the car fixed up before Area 27 later this month!
Heatsoak for sure. If you have access to E85 that will help with temps. Today it was over 100f so I can't imagine what the track temp was. If your running 5w30 that's the upper limit of what I would want to see. Your probably going to need to get a larger oil cooler radiator.
2013 Series 10 FRS #553
Old 08-03-2019, 09:14 PM   #184
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Definitely not just heat soak. I ran in similar temps a few weeks ago and the car ran fine. I’m just saying it could be a contributing factor. 13mph lost down the back straight is more than a few ponies missing!
mistople is offline   Reply With Quote
Old 08-03-2019, 09:48 PM   #185
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Sad to hear. But new personal best is great. That is really really hot. Reminds of pre oil cooler temps. I max out 240 or 241 at the ridge
Elliotw is offline   Reply With Quote
Old 08-03-2019, 11:02 PM   #186
Lantanafrs2
Drives: 2013 frs red
I hope you solve that issue. You've put a lot into your car.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
mistople (08-04-2019)
Old 08-04-2019, 03:30 AM   #187
jflogerzi
jflogerzi's Avatar
Knock so your IAM could have been below 1 and the combo of heat soak? But if you have no codes or cel... Very strange indeed.
Old 08-04-2019, 01:41 PM   #188
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Low IAM won’t throw a code.
Old 08-04-2019, 05:24 PM   #189
Lantanafrs2
Idk If theres any way to make these cars fast and reliable
Old 08-04-2019, 07:42 PM   #190
jflogerzi
jflogerzi's Avatar
Engine swap lol
The Following User Says Thank You to jflogerzi For This Useful Post:
Lantanafrs2 (08-04-2019)
Old 08-04-2019, 11:47 PM   #191
WC-BRZ
Drives: Black BRZ
LoL no kidding, eh! Whoever solves that puzzle stands to make a decent penny in the ft86 community!
WC-BRZ is offline   Reply With Quote
Old 08-04-2019, 11:49 PM   #192
WC-BRZ
Drives: Black BRZ
Engine swap lol
Ha! Not quite - he said "reliable" as well. Engine swaps for the most part have been a mess so far
Old 08-05-2019, 01:34 AM   #193
mistople
mistople's Avatar
I think several of the popular SC setups have proven to be quite reliable. It's clear that I have an issue with the tune—it's not like my engine has a hole in it!
But I get the point. If you want fast and reliable, buy a Porsche.
Old 08-05-2019, 01:58 PM   #194
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Did the car ever return to running normal?
Old 08-05-2019, 04:29 PM   #195
mistople
mistople's Avatar
Not sure yet. Haven't started it since I got home from the track. Busy with work! I'll find out more in the next few days once I can grab a log.
Old 08-05-2019, 04:32 PM   #196
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I hear that
I would check this first. Curious what the log shows.
https://www.ft86club.com/forums/showthread.php?t=109444
mistople (08-05-2019)
2017 BRZ Performance Package DD Build mjanmohammad Member's Car Journals 230 11-01-2023 12:31 PM
QueenBRZ's 17' BRZ performance package DD / track build QueenBRZ Member's Car Journals 125 06-29-2021 01:34 PM
Spicy.Ricecake's 2017 CWP BRZ PP Build spicyricecake Member's Car Journals 115 12-15-2019 07:42 PM
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
MVP Track Time 2014 Road Atlanta Track Dates Feffman Southeast 2 03-27-2014 06:51 AM
