Old 07-31-2019, 08:11 PM   #1
Olson1288
Olson1288's Avatar
Drives: 2014 DGM BRZ Turbo
TRD Spring Question
About to throw some TRD lowering springs on the car this weekend. I saw in a few pictures online that looked like the springs come with new bump stops? Bought mine second-hand and did not receive new bump stops.
For those of you with these springs, are the stock bump stops fine, or would you recommend cutting them a little when doing the install?
Also are there any special tools I'll need besides a spring compressor? Saw something about an open-end or spark plug type socket?
I hate my stock nasty wheel gap more then anything so I'm excited even if it's only an inch drop!
Oh and thank god for free alignments for life through Firestone.
Olson1288 is offline   Reply With Quote
Old 08-01-2019, 03:01 PM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Hey previous Firestone employee here! Yeah I love the Lifetime Alignment! Just amke sure your shop is capable of doing lowered vehicles. Not all alignment racks and machines are made the same. I realize I didn't answer you question... Sorry.
Drifter X is offline   Reply With Quote
The Following 2 Users Say Thank You to Drifter X For This Useful Post:
Olson1288 (08-01-2019), Tcoat (08-01-2019)
Old 08-01-2019, 03:20 PM   #3
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I bought new TRD springs last march that I haven't installed yet. Waiting on doing my clutch and turbo before I lower it.
It does come with bump stocks, I'm not sure how much they differ from stock.
For tools, I got the spring compressor ready. Though I heard you don't need them since the stock springs don't have enough force or you can undo the top hats or something while it's on the car?
For special tools, I believe all you need is an open end wrench so you can put an allen/hex key through.
Make sure to call the alignment place to see if they do lowered cars as mentioned. I'm calling around my local places to check as well.
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
Old 08-01-2019, 03:47 PM   #4
wparsons
wparsons's Avatar
You'll want spring compressors to get the stock springs off, they're under enough force that it won't be a fun time.
You'll also need either a strap wrench, or pass through socket, to loosen and tighten the top nut without spinning the shock shaft.
flickr
Old 08-02-2019, 12:28 AM   #5
Olson1288
Olson1288's Avatar
I've also seen some videos of people just removing the top hat/main strut bolt from the top and letting the spring basically decompress before removing the strut, we'll see if I end up grabbing a spring compress or not. Or maybe I'll just launch one across the garage
WK V3 - Spring Swap Question Stang70Fastback Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-18-2016 08:29 PM
Spring Install LCA To Hub Question FRS1010 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-14-2013 06:17 AM
Spring orientation question theom Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-05-2013 05:29 PM
Another annoying what spring to buy question shawnperolis Scion FR-S / Toyota 86 GT86 General Forum 45 04-27-2013 08:39 AM
To coilover or spring? That is the question... Knightmare Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 01-13-2013 10:34 PM
