go_a_way1
Old 08-01-2019, 12:29 AM   #5055
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Has anyone experienced a repetitive surging effect at partial throttle & low rpms?
My C30-powered car seems to occasionally buck/hiccup/surge under mild load. It typically happens when I'm going up moderate inclines in 2nd or 3rd gear around 2-4k. It almost feels like I'm quickly lifting off and pressing the gas repeatedly. I haven't had issues at mid to full throttle from what I can tell.
I've reached out to DT with my log but I wanted to ask here as well in case it sounds like a common tune or install related issue.
mistople is offline   Reply With Quote
Old 08-01-2019, 01:19 PM   #5056
sroby
Drives: 2015 Firestorm 08/05/15
No common, it sounds like it definitely is in the tune. If
it idles correctly, no chk lights, runs out good on bottom end and top end. Sounds like something isn’t correct in the mid range. Hope that helps
sroby is offline   Reply With Quote
The Following User Says Thank You to sroby For This Useful Post:
CSG Mike (08-02-2019)
Old 08-01-2019, 02:21 PM   #5057
jflogerzi
jflogerzi's Avatar
Agree tune related. I had this issue but was fixed during the revision process
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 08-02-2019, 11:20 AM   #5058
peaches
Drives: '14 BRZ Limited
Following Mike's advice, I did not track the car and it's currently being re-tuned. I was out of town for work and only just got to drive it, holy crap the difference it night and day. Definitively had a crap tune before, now I can really feel the JRSC working. Still need some revisions and dial in the flex fuel but I'm extremely happy. Now I truly know what all the fuzz is about.
peaches is offline   Reply With Quote
The Following User Says Thank You to peaches For This Useful Post:
Old 08-02-2019, 12:34 PM   #5059
jflogerzi
jflogerzi's Avatar
Who was your tuner before?
Old 08-02-2019, 01:19 PM   #5060
peaches
Olympic Motorsports in Margate, FL. He is listed as a master tuner and has good reviews online, Circuit Motorsports in Orlando did my NA tune but they never returned my emails or calls about tuning the SC.
Currently dealing with DT, compliments of my girlfriend who started the process while I was away for work.
Old 08-02-2019, 08:16 PM   #5061
mistople
mistople's Avatar
Yeah it runs great and pulls hard. Just very occasionally has that strange hiccup under light throttle.
DT isn't as fast to respond these days. Hopefully I can get an answer soon.
Old 08-03-2019, 02:49 AM   #5062
Kalamakid
Drives: 2014 FRS
I’ve been having the same issue. Thought it might be the recirculating valve. But maybe not. Started after I updated my tune with DT about 6 months ago. Any time I’m in second gear and pressing the gas lightly it slams/bucks from 2-5k rpms. Only way to get out of it is the press the gas or shift up. It’ll do it a bit in first gear as well but not as bad and 3rd has no issues. Makes driving in 30MPH zones weird as I’ve had to learn to get out of the “bucking” situation by feathering the gas. Didn’t think it could be the tune. Guess I’ll log it and see if they can help. FYI I have the c-38 tuned by Zach at DT.
Kalamakid is offline   Reply With Quote
Old 08-04-2019, 05:17 PM   #5063
teetsdownlow
Drives: 2015 FRS
Had the same problem with the stock tune. Unsure what it was or why it acted like that. Others seem to run flawless on stock file. But I reached out to DT and decided to run a flexfuel kit alongside a new fng tune to sort it out. No revisions on my tune and the bucking went away. Seems like a compressor surge to me. Could be a maf problem, tune problem, or the recirc valve is backwards
teetsdownlow is offline   Reply With Quote
Old 08-04-2019, 06:29 PM   #5064
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
I think I had a similar experience to you. Eventually got a P0172 code. After cleaning the MAF sensor and clearing the codes, it was back to normal. I tend to think this is maybe due to what seems to be a heavily oiled air intake filter, but I couldn't say for sure. This happened to me after about 1500 miles of use. Haven't had it happen since and I'm now around 3500 miles. To the extent that I still have lazy throttle response at lower RPM, I am going to try using a different recirculation valve as some others have done here, and see how that feels.
vfrqqq is offline   Reply With Quote
Old 08-06-2019, 11:20 AM   #5065
steved
Drives: 2013 FRS
Originally Posted by steved View Post
Anyone running the Verus brake duct kit with the JRSC kit? With the smaller wiper reservoir and the IC tubing I'm trying to remember how much space was left in there for brake duct tubing.
Just wanted to follow up; the duct kit will not fit with the supplied JR washer fluid reservoir/bracket. Looking at the perrin mount location it actually makes sense the JR one wouldn't fit, but I figured it out the hard way
steved is offline   Reply With Quote
Old 08-06-2019, 11:54 AM   #5066
steved
Drives: 2013 FRS
Track day overheating.
Setup:
2013 FRS
JRSC factory tune
JR dual radiator/oil cooler kit
Stock bumper/etc
OEM coolant (new)
Mobile1 5w30
Constraints:
No availability of E85
First time running JRSC at the track yesterday at Mission raceway near Vancouver. If anyone is familiar with the track its very tight and pretty short, front straight top speed with my setup was about 145km/h, and there are 3 straight sections. Track is known for being really hard on brakes, so you can probably imagine lots of running out the gears in 2/3 between the corners which means a lot of engine heat.
I threw a CEL after about 4 laps when ambient temperature was 29C (84F), coolant temperature sensor low voltage. My coolant temperature was pushing 250F+, and my oil temperature was pushing 270F. In follow up sessions I could get in 2 laps pushing pretty hard before oil temps would get closer to 260, and I'd have to manage heat by short shifting and not running WOT. Bit of a bummer to be honest.
Last session of the day I turned the heat on full and vented it out the passenger side, and my coolant temp didn't go above 240. I was able to run a full session like that, but I'm obviously uncomfortable with this amount of heat.
As an observation; a new Civic type R was also having heat issues, but that's nothing new. None of the other factory turbo'd cars at the track were doing limpy laps other than an STI.
I *thought* the dual radiator kit would work well but I'm wondering if it was a mistake to purchase it instead of the standalone oil cooler.
I'm looking for any ideas on how to reduce engine oil and coolant temps. I've thought about:
- venting the hood, but I'm trying to keep the car pretty low key exterior wise, and I'm doubtful it would make a big enough difference to be worth it
- changing coolant
- switching to a JR standalone oil cooler
- wrapping the stock header, not sure if this is even possible? I haven't looked at it yet, but usually oem headers don't have a lot of clearance for wrapping. I still have the oem heatshield so it would have to come off - not sure what decrease in temp I'd get
Overall I feel that there likely isn't one solution here and its probably going to be a combination of multiple fixes to get the temperature down, I'd also like some feedback if I'm going to put a ton of effort/time/money into trying to solve this issue and it might not actually be solvable.
Old 08-06-2019, 01:32 PM   #5067
mistople
mistople's Avatar
Setup:
- changing coolant
I'm also dealing with very high oil and coolant temps. I'm running the dedicated JR oil cooler with the setup integrated with the intercooler and rotrex cooler.
I saw 262F oil temps during a similarly hot track day this weekend. Really frustrating as I though I'd be rock solid in terms of heat management.
Old 08-06-2019, 02:16 PM   #5068
peaches
When I was NA I had a stock radiator and a Perrin oil cooler, tracks temps hovered in the 260 range so from my point of view, those temps while FI are not that bad.
Now I have the JR dual cooler, will be on track Labor Day weekend so we'll see how that goes.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
