Old 08-01-2019, 02:12 PM   #1
ciebs
Drives: 2016 Scion FRS
Wheel Size for TRD Lowering Springs
Hey Everyone.
I’m looking to get new wheels this weekend. Still running the stock ones.
I have TRD lowering springs - all other suspension components are stock. I’m hoping to graduate to an 18” rim. Does anyone have any insight if I’ll be safe with an 8.5 offset running 235-245 tires?
What’s my best bet for fitting? Thanks!
ciebs is offline   Reply With Quote
Old 08-01-2019, 02:16 PM   #2
xdavidx
Emperor McDuck
xdavidx's Avatar
Drives: 2019 86 GT; 2018 BMW S1000RR
This guy nailed it for best fit on 18s with 1 inch drop/trd springs
https://www.fitmentindustries.com/wh...wering-springs
xdavidx is offline   Reply With Quote
Old 08-01-2019, 02:18 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Welcome to the forum.
You can get 18x8.5 wheels with an offset of +45 to +25 Most get an offset in the +35 to +40 range.
Either size tire will work. though 245/35/ is closer to stock diameter. It is also a bit more costly. If on a budget, 225/40s will work great too. They are a super common size; thus cheaper. (usually)
Good Luck!
I LIKE TIRES!
Old 08-01-2019, 02:47 PM   #4
ciebs
Good Luck!
Amazing - thanks for the info buddy! Glad this will work with my lowering springs. Not quite ready to do coilovers (yet)!
The Following User Says Thank You to ciebs For This Useful Post:
Leonardo (08-01-2019)
Old 08-01-2019, 02:58 PM   #5
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I'm on factory TRD springs and my 245/40/17 +38 setup has no issues. But I cannot weigh in on 18s.
Nevermore is offline   Reply With Quote
FS: TRD lowering springs, ARP extended wheel studs, 20/25mm spacers supercharged2 Brakes, Suspension, Chassis 1 04-24-2019 12:48 AM
Best size lowering springs for a daily/drift car? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-10-2018 08:16 PM
WTB: Lowering Springs pooch Want-To-Buy Requests 1 03-29-2016 12:50 PM
Lowering Springs and Wheel Spacers... Size?? cjhopkins Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 03-14-2014 01:16 PM
Lowering car with springs... What else do I need? SurfAndSand Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-25-2013 11:39 PM
