Old 08-01-2019, 07:27 AM   #58857
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by cjd View Post
Late to the party but...
If you want to keep it (or a replacement... This one is probably shot) an inline softener and charcoal filter after plus annual cleaning with a citric/acetic acid solution is the trick. My Izzo Alex duetto ii (stupid fancy espresso machine) tanks are still in great shape as a result.
I'm just taking it out. Seems silly to have something using power to keep boiling water 24/7/365 when you can do the same thing in 30 seconds with the microwave.
I would like to get a water softner, but can't use the traditional type because you can't have the backwash going into a septic. I need to look into the type of service where they come out regular and change the tanks.
Sapphireho is offline
Old 08-01-2019, 07:53 AM   #58858
it seems bigger, stiffer and harder to work with - especially on my knees, -
Tcoat is offline
humfrz (08-01-2019), soundman98 (08-02-2019), Spuds (08-01-2019)
Old 08-01-2019, 07:56 AM   #58859
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Wasn't going to touch that one.
Old 08-01-2019, 07:58 AM   #58860
Also...
Tcoat is offline
humfrz (08-01-2019), Sapphireho (08-01-2019), soundman98 (08-02-2019), Spuds (08-01-2019)
Old 08-01-2019, 08:19 AM   #58861
I'm just taking it out. Seems silly to have something using power to keep boiling water 24/7/365 when you can do the same thing in 30 seconds with the microwave..
Yea, that is odd, I didn't realize they worked that way. I always assumed they worked like tankless water heaters where the water was heated at the time of dispensing. I mean, how much "instant hot water" would you have to use to where these even make sense?
Dadhawk is offline
Sapphireho (08-01-2019), Tcoat (08-01-2019)
Old 08-01-2019, 08:27 AM   #58862
Ours here heats like 2 gallons of it. I have never ever seen the point since the most anybody ever uses at a time is about a quart.
Tcoat is offline
Old 08-01-2019, 09:43 AM   #58863
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Clutch Dog View Post
Hell I am at 28 and I am falling apart.
ever sneeze and throw your back out sideways? >_<
Start taking care of yourself it only gets worse.
From years of playing sports, up till I was 32, I had a large amount of injuries that have forced me to take better care of myself. The worse of which was knocking the femoral head of my right femur through the back of the hip socket when I was 20. Joint injuries suck and are with you forever. I'm really kicking myself now for pushing so hard when I was young to more or less earn a participation trophy.
NoHaveMSG is offline
Clutch Dog (08-01-2019)
Old 08-01-2019, 09:44 AM   #58864
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Turn 20 today Though I don’t see the point. Can’t do anything I couldn’t when I was 19 (well legally)
Will BRZ is offline
The Following 2 Users Say Thank You to Will BRZ For This Useful Post:
Dadhawk (08-01-2019), humfrz (08-01-2019)
Old 08-01-2019, 10:03 AM   #58865
cjd
cjd's Avatar
Drives: 2017 BRZ
One place I lived growing up had septic and well and the softener changes. Also it would dye hair and anything else it touched...
I only have a softener inline with the espresso machine. A little under counter unit. And we loved having the instant hot while we did. Old house. Might skip it now that it's espresso and cold brew, no pour over. And the tea takes more attention to water temp than an instant gives. It was a huge luxery in the old place though.
Now I just want a kitchen designed for cooking, not microwaving meals.
cjd is offline
Old 08-01-2019, 10:19 AM   #58866
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Got my corner cabinet built. Kinda tricky with two curves. Installed a light that turns on when you open the door. Also installed my DC TV/DVD on a drawer slide. ( its got a black elastic strap holding it in place in the photo) I can move it if I'm cooking to avoid heat damage or If I want it centered on the couch. It moves 23", or over the sink. (this also allows access to the rear of the tv while standing in the door way)
Installed the center trim strip from the headliner with some screws, that an upolstered button covers, between the side doors and passenger door to trim that part out. Oh, and installed a strap that secures the 5gal propane tank. I also installed led interior lights that are attached to a switch on the dash that was already there.
What I've got left to finish: the passenger seat swivel install, front door panels, the dash, and the roof rack /awning. Possibly forgetting something
I LIKE TIRES!
Leonardo is offline
The Following 6 Users Say Thank You to Leonardo For This Useful Post:
humfrz (08-01-2019), Nevermore (08-01-2019), NoHaveMSG (08-01-2019), soundman98 (08-02-2019), Spuds (08-01-2019), wolffbite (08-01-2019)
Old 08-01-2019, 10:29 AM   #58867
What the heck were you doing, skydiving without a parachute? -
humfrz is offline
Old 08-01-2019, 10:32 AM   #58868
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Racing Motocross.
humfrz (08-01-2019)
Old 08-01-2019, 10:38 AM   #58869
HAPPY BIRTHDAY!
humfrz is offline
Will BRZ (08-01-2019)
Old 08-01-2019, 11:19 AM   #58870
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Started at around 207lbs and have been working out almost two months. My weight is hard to change, especially since I don't do cardio. I'm eating healthier than I was before, but my calories eaten/burned is pretty much even it seems. I hit 204lbs last week but was bad over the weekend and weighed 207 on Monday. Back down to 204 this morning haha
Nevermore is offline
