#309 | |
Drives: Moped
Yup, then the only issues becomes successfully collecting on the judgment, which is usually a bigger problem with random individuals and not so much large entities. |
#310 | |
Drives: Moped
This is extremely helpful. Thank you! |
#311 |
Drives: Thee Argento Cricket
I have a massive oil leak post-recall work done. I've been in contact with the service writer who helped me. He mentioned it could be the timing cover.
Shouldn't that be covered since the mechanic needed to disassemble the motor to get to the valve springs? |
#312 |
Benz Tech
Drives: 2017 BRZ Premium
Yes. Unless you have a cold air intake. Then they're going to throw you under the bus.
#313 | |
Drives: 2012 Scion FR-S
Honestly, fuck this car, I don't even want it back. Next time he calls me, I'm just gonna ask him if i can keep the Corolla as a straight trade for my FR-S :p |
#314 |
Drives: 2013 FR-S, 6MT, Daily Driver
Friendly reminder to all Canadians who had their engine blow up after the recall to lodge a complaint with Transport Canada: https://wwwapps.tc.gc.ca/Saf-Sec-Sur....aspx?lang=eng
| The Following User Says Thank You to used2likeit For This Useful Post: | SPEEDGOD (07-30-2019) |
#315 | |
| The Following User Says Thank You to NickCarmer For This Useful Post: | humfrz (07-26-2019) |
#316 |
Drives: 2013 Ultramarine Scion FR-S
Vehicle Mileage:~87,000
Vehicle Make: FRS Mileage After Recall Performed: ~85,000 Symptom(s): Rod Knock, Power loss Failure: TBD, most likely spun rod bearing State: In dealer with engine being striped, new short block just came in Is Dealership Offering Repair: Yes, no hassle or arguing, brand new short block, unsure if reusing cams. |
| The Following User Says Thank You to Little Mt. Fuji For This Useful Post: | gravitylover (07-31-2019) |
#317 | |
I don't lie.
Drives: AE86 Successor
I'll get a Mustang for way less if I wanted more power.
#318 |
Drives: 2013 Scion FRS
Well it finally happened, funny thing is I only got the recall because a friend of mine had it done earlier and put on tons of kilometres without issues. I swear the day my car was ready to be picked up after the recall, he spins a rod bearing.
When I went to pick up my car today, there were three cars sitting in the lot with dead engines. Vehicle Mileage: 119000 km Vehicle Make: 2013 FRS Mileage After Recall Performed: 2000km Symptom(s): loud knocking, started at around 5k rpm and car shut off shortly after Failure: tbd State: Ontario, Canada Is Dealership Offering Repair: No, because car was out of warranty, dealership wanted to charge labour to start any diagnosis. Service tech said it would be a waste of time/money because I obviously needed a new engine and sent me straight to Toyota Canada to try to start a claim.
![]() 2013 Firestorm Scion FRS 2005 Civic SI Sedan- Sold 2004 Impreza WRX - Sold 1992 Civic Hatchback - Parted, RIP |
#319 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#320 | |
#321 | |
Benz Tech
We know it was due to the recall, but if the dealership doesn't want to back it up you will have to fight it. If you remove a door panel and replace a window motor the window motor has a 12 mo warranty. The door panel does not inherit any of that warranty. If the tech breaks the door panel taking it off and glues it back together, which later falls off when you slam the door... that's on the dealer. It's just like that. But $10k. |
#322 | |
Of course, that is expecting good faith on the part of the dealer I realize...
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 07-31-2019 at 11:59 AM. |
| Tags |
| fa20, failure, recall, spun bearing, subaru, toyota, valve spring |
| 2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 06:21 PM |
| TSB / Recall thread take over | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 17 | 02-18-2019 11:24 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| PA Monogram Registry! | kazetaro | NY / NJ / CT / PA | 0 | 06-06-2014 06:49 PM |
| Another Detonation thread. (DI failure related) Input Please. | Thorpedo | Issues | Warranty | Recalls / TSB | 15 | 08-02-2013 07:23 PM |
