Old 07-29-2019, 01:11 AM   #15
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Originally Posted by LimitedSlip View Post
But the sealed box will produce tighter, more accurate bass assuming the amplifier has an adequate dampening factor so as to control the excursions of the driver.
Kind of depends if you are interested in music or sound effects. Its always about compromises. Just sayin' . . .
Yes it's about compromises.
But.... depends how the vent is tuned. If it's tunes for a lower frequency it matters not. It's just going to be a bigger box.
Back in my bass head days I always tuned my ports for 35 hertz. Now that's pretty fucking deep. Sure it was 3 cubic ft box but dam with only 300 watts at 135 db. Yeah I won a few awards at the db drag events long time ago.
Old 07-29-2019, 06:02 AM   #16
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
So the box makes a difference too?
Howaitoguru is offline   Reply With Quote
Old 07-29-2019, 06:18 PM   #17
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Oh hell yes.
The Following User Says Thank You to Mr.ac For This Useful Post:
Leonardo (07-29-2019)
Old 07-29-2019, 06:26 PM   #18
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This explains things better than I can...
http://audiojudgement.com/thiele-sma...ers-explained/
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Mr.ac (07-29-2019), soundman98 (07-29-2019)
Old 07-29-2019, 07:40 PM   #19
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
How dare you use math to explain subwoofers and boxes.
Just buy a 4th order bandpass cause I'm a bass head.
Or just buy a vented box cause I like rock.
That's sarcasm by the way.
That's a good read.
Leonardo (07-30-2019)
Old 07-29-2019, 10:49 PM   #20
soundman98
ProCrastinationConsultant
soundman98's Avatar
absolutely. the box is the acoustic space that any speaker operates. you can change how loud your voice is just by cupping your hands around your mouth, the same principle applies to any acoustic device.
here's a video where the same speakers are used in 2 different boxes.
[ame]https://www.youtube.com/watch?v=LNGSNqz7-rs[/ame]
That's a good read.
good thing you said it was sarcasm or i was gonna, well, nevermind.
will a bandpass box even fit in these cars?!?
considering that the trunk is 6.9cu ft, i seriously considered sealing the whole thing and using it as the box for 2 15's... i couldn't even run a 10 free air with that!
Impureclient (07-30-2019)
Old 07-30-2019, 05:58 PM   #21
Howaitoguru
So let’s simplify it since you guys know what you’re talking about. If I bought 1 JL W6 10” sub what kind of box should I use? I wanted to get a wheel well box made. However idk if I’ll have enough space to fit that speaker in there. Also what size amp should I run for just that? I was going to get a separate amp for door speakers when I upgraded that. Lastly I wanted to upgrade the head unit and get a capacitor. I’d like it to be simplified. And I’d rather not spend $3000 at radioactiv for a subpar system.
Old 07-30-2019, 06:09 PM   #22
Howaitoguru
Originally Posted by Drifter X View Post
10" JL W6v2 in a factory spec sealed box and 600w in my trunk. I freaking love it.
What’s a factory spec sealed box? Do you think I could get that speaker to fit in my wheel well?
Old 07-30-2019, 06:09 PM   #23
Leonardo
Country Boy 4 Life
Leonardo's Avatar
JL makes a wheel well sub box for our cars. It comes with a woofer, not the one you mentioned. IMO, caps are totally unnecessary, especially for the system you are building. An amp should have enough power for a woofer. I think 200 to 500 watts is a good size sub amp. I had a 100watt x 2 sony Mobile ES amp hooked to two 15" Rockford Fosgate DVC woofers. It hit 137db. So, not all amps are created equal. Anyway, you get what you pay for. (luckily these days car stereos are way cheaper than in the 90's when I was installing them)
https://www.crutchfield.com/S-9m6uFl...SABEgIovfD_BwE
I LIKE TIRES!
Howaitoguru (07-30-2019)
Old 07-30-2019, 06:41 PM   #24
Howaitoguru
Unfortunately I can only find the stealth box that goes in the side.
Old 07-30-2019, 07:11 PM   #25
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Do you mean the kind that fits in the spare tire?
I LIKE TIRES!
Old 07-30-2019, 10:27 PM   #26
soundman98
soundman98's Avatar
you'd need almost 7" of depth for a w6. i don't believe there's 7" of depth anywhere in the car..
i believe the integrity concepts box might be deep enough, but integrity went dark about a year ago. my stolen box is likely floating around, but i'll give anyone $200 that can find it.
i'm running a 6" deep sub(peerless xxls 10"), and the airspace is just barely what's needed. i think a w6 would be oversized for the box.
why a w6?
what exactly are your goals for space, and expectations for loudness?
any car audio shop is going to encourage you to buy everything, what are your overall goals? 2 amps in 2 separate installs is going to be a pain.
Old 07-30-2019, 11:26 PM   #27
Howaitoguru
why a w6?
My body has a w6 12 in his Kia telluride and it hits so hard. I figured a 10 would be solid. But I was also told to get two 10’s in a ported box by someone else. And it should hit fairly hard especially since I removed the back seats. I’m so confused. The audio shop by my house is so expensive. They mark up everything 40% but idk I just want a system that hits hard. People keep telling me different shit and I’m getting confused.
Old 07-30-2019, 11:27 PM   #28
Howaitoguru
Yeah JL doesn’t have one. They just have stealthboxes that go in the passenger side space in the trunk. I guess that’s technically the wheel well too huh? But yeah I meant the wheel well for the spare.
The Following User Says Thank You to Howaitoguru For This Useful Post:
Leonardo (07-31-2019)
Let's Talk Speakers ecko04 Electronics | Audio | NAV | Infotainment 27 11-11-2013 03:43 PM
Talk me into, or out of, a Mac Chimpo Off-Topic Lounge [WARNING: NO POLITICS] 49 06-18-2013 01:37 PM
Car talk calis5nest FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 05-02-2013 02:04 PM
Dyno talk Rayme Other Vehicles & General Automotive Discussions 2 03-06-2013 09:24 AM
BMW talk RaceR Other Vehicles & General Automotive Discussions 101 01-15-2013 11:32 AM
