Old 07-27-2019, 03:52 PM   #1
enderw88
Drives: 2015 BRZ WR Blue Series.Blue
BRZ Series Blue starting is flaky
I am having a hard time searching for information on this question. It is difficult to describe without words that throw up 10000 unrelated threads.
2015 BRZ Series Blue, no known mods. I have had the car for about a month.
About 1 time in 10 the car engine won't crank. The instruments cycle and it appears everything else has come up normal. Once this happens, it can take several attempts turning off and back on to get the engine to start. I am careful to make sure the clutch is fully depressed and the green key symbol is showing before I hit the button. I have tried to figure out whether it is depending on brakes being depressed or the shifter being in gear or neutral but I can't find any common factor. It seems like a crap shoot to get it started once this has happened. I don't even know where to start trouble shooting. My first thought was a flaky clutch interlock switch. Any other ideas?
2015 BRZ Series.Blue
2006 Moto Guzzi V11 Sport Laverda
1976 Yamaha RD400 TZ
enderw88 is offline   Reply With Quote
Old 07-27-2019, 04:45 PM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
The easiest thing is to check power to the starter when the issue occurs. I’d start there absent any real diagnostic equipment. Do you get any click or anything?
The big wire has power all the time. The little wire gets power when you crank. Power at the little wire and no crank= bad starter.
Search no crank no start, include FRS and BRZ.
maslin is offline   Reply With Quote
Old 07-27-2019, 05:12 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
have you tried replacing your key fob battery?
it's the easiest of any of the possible solutions to do, so i usually start there with no-start issues.
Old 07-27-2019, 06:05 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well since it is a '15 it could be the early signs of a dying battery.
Second guess, maybe there is some corrosion on the contact terminals.
Old 07-27-2019, 06:15 PM   #5
computeruser
Drives: 2015 BRZ
The 2015 batteries are known to be rubbish, so that’s probably somewhere to consider starting...
computeruser is offline   Reply With Quote
Old 07-27-2019, 06:29 PM   #6
enderw88
Yep. Did that the day I got it. One of them didn't work at all so replaced them both.
This is a good idea, Tucson destroys car batteries.
I don't hear a solenoid picking up when this is happening. I need to pack a VOM or come up with some way to troubleshoot this.
I will start with the battery terminals.
Old 07-27-2019, 06:51 PM   #7
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
First thing I would do is make sure nothing is blocking the clutch contact. Too much carpets, etc can block that and make it not start. i've had that happen.
Second thing is car battery or starter is dying.
why? is offline   Reply With Quote
Old 07-27-2019, 07:48 PM   #8
extrashaky
Drives: 2014 BRZ Limited
Wasn't there a thread where the guy did that silly clutch adjustment and ended up with the same symptoms?
If it has the original Painasonic battery, it's probably time anyway. Those aren't that great brand new.
Old 07-27-2019, 09:47 PM   #9
+1 for @maslin's advice.
It's not the key fob battery. Otherwise, valet keys would be useless.
You can start with the battery but if it works after several attempts then that's not it. Your intuition about its likelihood of being an intermittent connection is good.
It's also good that you recognize not hearing the bigger sounds that you might expect to hear. First completely rule out the starter, and this includes looking for signal on the little connector. Only if it's not there should we start looking for stuff upstream. There's a relay to check if you don't see power at the smaller connector when the key is turned.
Old 07-27-2019, 10:46 PM   #10
This is where I would start. The battery wiring is static so several attempts should not change the results. The clutch switch could be faulty, blocked or messed with so you need to have exactly the right pressure on it for it to work.
Old 07-29-2019, 01:27 PM   #11
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Sounds like a bad ground. Make sure your battery and/or starter are properly grounded. Good luck!
MJones_RB is offline   Reply With Quote
Old 07-29-2019, 08:49 PM   #12
enderw88
Thanks for the suggestions.
The battery is not the OEM battery, but I couldn't find a date code on it. I pulled the terminals and cleaned them up, though there wasn't any visible buildup. Battery measured 12.6V, but I put it on my CTEK conditioner overnight. I will try to get to the starter terminals. I haven't yet gone under the dash to check the clutch switch.
Old 08-16-2019, 02:45 PM   #13
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Is it doing something like this ??
mswbrz is offline   Reply With Quote
Old 08-22-2019, 01:17 PM   #14
FineVisionz
FineVisionz's Avatar
Drives: Series.Blue
Hello fellow Arizona Series Blue owner! Nice to see that there are some other Series Blue in Arizona!
When you push your clutch in does the green light on your dash stay solid green or does it flash?
If it flashes, then it's your clutch positioning sensor. There's two of them, one is for start up and the other one is for cruise control. They're both located right next to each other by the clutch pedal. The bottom one is for your cruise control and the top on is for start up.
I had this problem a few months ago and replaced mine and it fixed it.
I used this video to help determine what was wrong and how to fix it,
[ame]https://www.youtube.com/watch?v=uGfKbbShpaM[/ame]
If you have any other questions, feel free to ask!
Hope to catch you out at one of the Arizona86 meets!
https://www.facebook.com/groups/1422313724716286/
FineVisionz is offline   Reply With Quote
starting
Looking for a set of Oem Series Blue Seats or hyper series blue Darth Want-To-Buy Requests 1 11-02-2018 12:28 AM
FS; 2016 Series Blue Interior Part Out! Hyper Blue Series sokol Interior Parts (Incl. Lighting) 47 08-05-2017 10:57 AM
Hyper Blue fender garnish on a Series Blue BRZ - with Pictures chamourian Cosmetic Modification (Interior/Exterior/Lighting) 20 05-13-2016 04:33 PM
2015 BRZ Series.Blue STI Turbo 5k miles Manual Fully Loaded + blue LED conversion bren5279 Cars for Sale/Trade 40 04-21-2015 10:32 PM
