Old 07-27-2019, 05:22 PM   #3165
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
While I'm going to wait until the bypass valve issue is fixed or a new one is developed, is there a different part number for the SC other than 15560/1556 for the +17 model years?
Different vendors have applications listed for 13-16, 12-15 and 13-17, but does the E-Force fit the 18/19 models?
BA9092 is offline   Reply With Quote
Old 07-27-2019, 07:56 PM   #3166
marco1ca
Drives: Toyota Celica
Well, I just got my '13 brz back from the Recall work, hopefully, by the time I put 5000 miles on it with oil analysis along the way, this issue will be fixed. Would be nice to get "Edelbrock weekly Bypass Valve fix updates"
marco1ca is offline   Reply With Quote
Old 07-27-2019, 10:50 PM   #3167
Mr_Eyo
Drives: 2017 Toyota 86
Nope, same part number but newer kits are compatible with 13-16 and 17+.
Mr_Eyo is offline   Reply With Quote
Old 07-27-2019, 10:56 PM   #3168
BA9092
Captain Slow
BA9092's Avatar
Ah, thank you for the info!
Old 07-28-2019, 11:01 AM   #3169
CSG Mike
CSG Mike's Avatar
Same part number, but any current kit fits all model years.
CSG Mike is online now   Reply With Quote
Old 07-31-2019, 02:42 AM   #3170
HachirocksU
Drives: Friggin Really Sweet
How is the MPG on this kit with conservative driving? Thank you.
HachirocksU is offline   Reply With Quote
Old 07-31-2019, 02:56 AM   #3171
CSG Mike
CSG Mike's Avatar
unchanged to -5%, if you drive EXACTLY the same as before boosting.
Of course, with how easy to accelerate it is, you'll likely be driving slightly faster, even under totally normal conditions.
Old 07-31-2019, 08:03 AM   #3172
hellb0undh0und
nerd
hellb0undh0und's Avatar
Drives: 17 Limited PP BRZ
I lost almost exactly 3 mpg. That said, I also switched to bigger injectors.
hellb0undh0und is offline   Reply With Quote
Old 07-31-2019, 10:17 AM   #3173
Silvermk2
Drives: Toyota Supra 2JZGTE VVTi
I get about 22-24 down from about 27 before. I'm probably 75 highway / 25 city. I think it might get 28 on the freeway if you had perfect throttle control, but the instant gas thing drops down to 6.6 anytime there is any throttle increase. Problem is it makes boost really early and at low throttle, which makes it drive great but increases your fuel usage. I think a turbo would get better gas mileage since probably anything less than 3500 rpm mid throttle is in vacuum still, but that is just a guess though.
Silvermk2 is offline   Reply With Quote
Old 07-31-2019, 12:41 PM   #3174
HachirocksU
Yes because of how easy it is to accelerate with the rpm able to rise so quickly had me thinking of how it will affect mpg on normal daily driving. Thanks all for answering. Thisll be the kit.
Old 07-31-2019, 01:32 PM   #3175
86fun
Drives: 2013 FRS
I did an extreme mpg test before and after, where I tried to get the very best MPG I could possibly get. This is driving with very little throttle input mind you. Not realistic, since the SC never even kicked in, but I did the same test before and after. 70% highway, 30% city with some elevation changes. Before: 40mpg over the period of a whole tank, after 37-38mpg over the period of a whole tank. Yea, about 5% in that case. I would argue that under heavier loads (SC kicking in a lot) it's going to get quite a bit less though, after all it's generating about 40% more HP than stock!
Now if I flog it a bit and drive normal to hard on the street, I get about 27mpg over a whole tank. No other mods.
86fun is offline   Reply With Quote
Old 08-01-2019, 10:13 AM   #3176
toast
Drives: 14 BSP Edelbrock BRZ
My results mimic @86fun. I reset my mileage on every tank, I used to get 27-28/tank and now get 26-27/tank. The more highway you do, the better. I did a full tank of highway driving and averaged 33 mpg, but I'm on long island and we aren't known for our hills so YMMV.
toast is offline   Reply With Quote
Old 08-01-2019, 10:30 AM   #3177
jflogerzi
jflogerzi's Avatar
You guys are lucky. With e85 and my sprintex kit my milage is getting killed. Lucky to get 150 miles with all city driving
2013 Series 10 FRS #553
Old 08-01-2019, 11:12 PM   #3178
Mr_Eyo
I'm all city driving. 20 mpg on 91, 14 mpg on E85.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
