Old 07-18-2012, 12:25 AM   #29
CU2MIKE
Drives: Nissan Altima, plan to get a FRS
Originally Posted by kwood9000 View Post
I think my 3000 psi pressure washer may be a bit much.
What sort of pressure washer and foam cannon do you use?
I use an electric one, Karcher 5.85M, it's one of the higher end consumer units that comes with a metal pump. I can't be using a gas powered unit after all, my neighbors would hate me if I did every other morning at 7am, lol.
Foam cannon I use this one called Auto Glos, forum member and fellow detailer autoaesthetica is the one who carries it.
CU2MIKE is offline   Reply With Quote
The Following User Says Thank You to CU2MIKE For This Useful Post:
kwood9000 (07-18-2012)
Old 07-18-2012, 12:28 AM   #30
Hamza7
Drives: MiniVan
Please note* that all products that Mike has listed above can be purchased at autoaesthetica, he is a user on this forum. Please PM him, he ships throughout the US and in Canada.
Hamza7 is offline   Reply With Quote
The Following User Says Thank You to Hamza7 For This Useful Post:
Old 07-18-2012, 11:49 AM   #31
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Would I need to get any special adapters to connect the foam cannon to the Karcher?
Thanks.
kwood9000 is offline   Reply With Quote
Old 07-18-2012, 09:29 PM   #32
CU2MIKE
Thanks.
Yup, you'll need an adapter, here it is
http://www.pwmall.com/p-139832-bay_k...ing-brass.aspx
You'll need this as well
http://www.pwmall.com/p-133176-14075...ple-brass.aspx
Old 07-19-2012, 12:37 PM   #33
Hanakuso
Originally Posted by driv3r View Post
actually, the proper method is the three (3) bucket method. this prevents any dirt/grime from the wheels, which are always the dirtiest parts of the car, from getting onto your paint.
1. strictly for wheels
2. shampoo only
3. rinse water
if you can get past the blatant product promotion, this video is quite helpful
What type of liquid did he use to dry the car off? Some kind cax?
Hanakuso is offline   Reply With Quote
Old 07-19-2012, 01:10 PM   #34
autoaesthetica
Drives: Shiny
2. shampoo only
3. rinse water
Using separate wheel materials is not new practice and should otherwise be observed by everyone. I would recommend a lighter colored bucket and materals over a black one for the simple purpose that even though it will darken over time, being able to tell if a rock or jagged tar glob gets stuck in your brush or mitts is priceless when you consider the damage of scratching a rim.
The faux sheepskin mitt he uses marrs the snot out of medium and soft paints - its acrylic, but I would be willing to bet he sells this with this line.
The other thing not mentioned is the fact that regular sealant wax users will probably have a shorter life of protection with the foam gun. Think about it, soaps are designed to remove dirt and oil. Wax is a lipid by nature. Constant hand washing over time removes body oil and dries your hands - same idea but with non living things.
Its not a new practice to use a QD or a spray wax to avoid water spotting - OC/OG coated or not, you guys should be using a quality QD to add slickness to the paint while drying. Though I would be very carefull driving around the block after drying, you will be rewiping a street dusted car which in some ways may not be the best idea...
Mike Fortunato | Auto Aesthetica Facebook
■ Opti-Coat Installer | Subaru Detailing Expert
Tel : (716)860-6366
Web: www.DetailWNY.com
Email: Michael@DetailWNY.com
autoaesthetica is offline   Reply With Quote
The Following User Says Thank You to autoaesthetica For This Useful Post:
tripjammer (12-24-2012)
Old 07-25-2012, 01:05 PM   #35
hankster
hankster's Avatar
Drives: 2013 FR-S Argento
... I cheat by using a pressure washer and foam cannon, lol.
how do you cheat - how do you use the pressure washer and foam cannon in the cleaning process? I'm only now learning about proper cleaning and I've read threads about foam cannons and threads about 2-bucket method but I haven't come across a discussion that puts the two together.
hankster is offline   Reply With Quote
Old 07-25-2012, 05:44 PM   #36
CU2MIKE
The whole reason detailers use pressure washer and foam cannon is because this combo will produce foam so thick it's similar to shaving creme.
What this does is it knocks loose and takes down majority of the dirt, thus reducing the chance of marring and swirling up the paint during the actual 2 bucket method (It also allows me to get a little sloppier with my 2BM technique), that's why I said I "cheat"
hankster (07-25-2012)
Old 07-26-2012, 12:39 PM   #37
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Mike, car was scratched (see thread http://www.ft86club.com/forums/showthread.php?t=12827 )
Any recommendations. It does not look too deep and perhaps didn't mess up the full depth of the opticoat.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 07-30-2012, 11:34 PM   #38
KlafKoon
Drives: 2013 H8R FRS, 03 Miata (Sold)
Mike, new respect for you! I just picked up a Karcher 5.85m off craigslist for a great price. I didn't expect that thing to weigh as much as it does. I commend you for lugging that thing around. Luckily it works great and hopefully will for a long time from now.
KlafKoon is offline   Reply With Quote
Old 07-31-2012, 11:22 AM   #39
l0xns0cks
Drives: 2013 Scion FRS Raven
Thanks for the terrific list, Mike. Will be trying this after I get my opticoat installed
l0xns0cks is offline   Reply With Quote
Old 07-31-2012, 11:36 AM   #40
autoaesthetica
Drives: Shiny
Would you guys like me to just build maintenance product kits that WE KNOW work perfectly with subaru and toyota vehicles for your aftercare?(Both coated and non coated)
Interior and Exterior Kits?
Say the word - and I can build them for you guys.
Tel : (716)860-6366
Old 07-31-2012, 07:51 PM   #41
kaisernaut
kaisernaut's Avatar
Drives: 2011 Chevy Silverado RCSB
Yes please!
kaisernaut is offline   Reply With Quote
Old 07-31-2012, 07:51 PM   #42
OrbitalEllipses
Drives: Attitude
Originally Posted by kaisernaut View Post
Yes please!
Seconded.
Why Opti-Coat your Car? Hamza7 Cleaning and Detailing 234 07-30-2012 10:13 PM
Opti-guard , is it really worth it ? mashal Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 38 07-29-2012 05:36 PM
Opti coat near me Nate219BRZ Cosmetic Modification (Interior/Exterior/Lighting) 7 07-20-2012 08:24 PM
Whiteout FRS Opti-Guard Calgary Bu-Tang Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 07-03-2012 01:45 PM
Opti Guard/Coat, Xzilon pain protection jaytaurus Northwest 3 07-01-2012 05:47 PM
