Old 07-20-2019, 09:24 AM   #15
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
@Ebush
Ok $7500 is your cheap. Good to know.
Old 07-20-2019, 10:10 AM   #16
vijay.dy06
Drives: Red BRZ
Originally Posted by ShibusaTouge View Post
The only difficult part about this swap so far is the gas pedal and power steering.
You can use an 04 ish WRX dbc gas pedal. Just need to fab up a bracket for it. Easy to do with an angle grinder and drill.
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 07-20-2019, 04:04 PM   #17
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2300LB FRS
First video is up!
ShibusaTouge is offline   Reply With Quote
Old 07-20-2019, 10:49 PM   #18
ShibusaTouge
Drives: 2300LB FRS
video is up!
Old 07-21-2019, 10:38 PM   #19
Irace86.2.0
video is up!
I think this is what you wanted...
[ame]https://www.youtube.com/watch?v=DZOy2VMYbIM[/ame]
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
ShibusaTouge (07-22-2019)
Old 07-22-2019, 07:37 PM   #20
ShibusaTouge
Drives: 2300LB FRS
Haha thank you!
Old 07-24-2019, 10:05 AM   #21
ShibusaTouge
Drives: 2300LB FRS
Why I chose the k24 over the 2JZ or LS!
Old 07-24-2019, 03:29 PM   #22
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Swap out to electric power steering/rack. Some guys use the S2000 system?
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 07-28-2019, 08:59 PM   #23
ShibusaTouge
Drives: 2300LB FRS
Engine work has begun!
Old 07-29-2019, 10:47 AM   #24
wparsons
wparsons's Avatar
The stock power steering is already electric... the motor is just on the column instead of in the rack.
flickr
Old 07-29-2019, 10:50 PM   #25
ermax
ermax's Avatar
That thing is a mess. Should have thrown some degreaser at it before cracking it open.
Old 07-30-2019, 02:30 PM   #26
Swift
I just Drive.
Swift's Avatar
Yes, my apologies. Would you get more room swapping to someone else's design??
Old 07-30-2019, 04:54 PM   #27
ermax
ermax's Avatar
The OEM rack is very compact. The assist motor is mounted to the column right behind the gauge cluster inside the cockpit. They specifically went with this layout to allow them to put the motor as low and far back as possible. Other Subarus do not use this layout.
The Following User Says Thank You to ermax For This Useful Post:
wparsons (07-30-2019)
Old 07-30-2019, 06:37 PM   #28
wparsons
wparsons's Avatar
If anything you'd probably lose space going to a different rack.
flickr
honda, k24, racecar, swap, vtec
K24, let's do this. TheVTEC86 ShibusaTouge Member's Car Journals 23 08-14-2019 06:56 AM
