Old 07-20-2019, 10:14 PM   #183
CSG Mike
CSG Mike's Avatar
Originally Posted by Quasimofo View Post
And this right here is why I hate forced induction. I have never once driven a FI car that has that immediate throttle response that I crave in a fun vehicle.
If it doesn't have good throttle response, might as well slap an automatic on it and let the damn transmission sort it out.
Fingers crossed that this doesn't require a full ecu swap; I don't like having to dodge vehicle inspections 'cause the diagnostic port is a road to nowhere.
Sounds like you've never really driven FI done right!
CSG Mike is online now   Reply With Quote
Drifter X (07-21-2019), Summerwolf (07-21-2019), TheStig85 (07-21-2019)
Old 07-21-2019, 09:45 AM   #184
Quasimofo
Quasimofo's Avatar
Drives: 2019 Series Gray BRZ
Perhaps; I mean, I have never driven anything with a supercharger. But I'm really not sure a turbo'd engine can be made to feel acceptable to me. Always open to being proven wrong, but I'm a pretty big n/a fan. The faster the revs rise and fall the better. Make it feel as responsive as a superbike engine and I'm sold.
Which is why I'm here in the itb thread lookin' at parts that cost almost as much as a turbokit
Quasimofo is offline   Reply With Quote
The Following User Says Thank You to Quasimofo For This Useful Post:
why? (10-29-2019)
Old 07-21-2019, 10:24 AM   #185
churchx
churchx's Avatar
Drives: 2014 GT86
Turbo is not the only way of forced induction (though even it can be made right with little to no turbo lag). Ever heard of supercharging?
Old 07-21-2019, 10:49 AM   #186
Lantanafrs2
Drives: 2013 frs red
LS swap
Lantanafrs2 is offline   Reply With Quote
Old 07-21-2019, 04:59 PM   #187
CSG Mike
CSG Mike's Avatar
The fundamental concept of turbocharging means there will always be a delay, but that transient spoolup can be minimized.
With a proper clutch setup, a turbo will still be more responsive than a stock engine and tune that has excessive transient ignition retard.
Superchargers will have zero lag.
Tokay444 (07-21-2019)
Old 07-21-2019, 10:37 PM   #188
Tokay444
Thankfully, no automotive engineer on the planet gives a flying fuck what you feel is acceptable. Especially when there isn’t a single modern turbo that suffers from anything you could claissify as a lack of throttle response. Turbo cars can suffer from transient response, depending on the size of the turbo, but the throttle plate opens the second you mash the gas on pretty much all of them.
I’m going with, you just don’t know what you’re talking about. And that’s fine.
The speed with which revs rise and fall have absolutely zero to do with induction type. This is all relative to mass of the rotating assembly, including the flywheel. You’ve proven my point.
You’re free to like and dislike whatever you want, for whatever reason, but you should at least have an educated opinion.
The Following 3 Users Say Thank You to Tokay444 For This Useful Post:
Drifter X (07-22-2019), Hawk77FT (07-22-2019), re-animator (09-03-2019)
Old 07-22-2019, 12:28 AM   #189
Lantanafrs2
The thing can be responsive and still slow lol. Forced induction to make power, na to make a point
Old 07-22-2019, 01:02 AM   #190
Hawk77FT
Drives: GTS 86
I am considering the ITB with velocity stacks, however I am still wondering how can we deal with the MAF sensor missing? Is there a way to trick the ECU?
Hawk77FT is offline   Reply With Quote
Old 07-22-2019, 07:19 AM   #191
Quasimofo
Quasimofo's Avatar
Originally Posted by Lantanafrs2 View Post
LS swap
Already got an LS7 in another car, don't want to step on any toes.
If I'm swapping motors, I'd sooner just sling a bridgeported 2 or 3 rotor in there so it would rev like a madman and scare people.
Lantanafrs2 (07-22-2019)
Old 07-22-2019, 07:23 AM   #192
Quasimofo
Quasimofo's Avatar
Have you driven a current model STi? It does not have what I call "snappy throttle response." With throttles no longer being cable controlled, are you really getting the throttle opening you think you are? The base BRZ plays games with throttle opening to try to game that torque hole. But thats besides the point.
I'm also well aware what lighter flywheels do. I've run 9 and 11 pound units in other cars.
I don't like turbos. I prefer N/A. It's a free country.
At the end of all this, I just hope there's another useful product to spend money on.
CSG Mike (07-22-2019)
Old 07-22-2019, 08:24 AM   #193
churchx
churchx's Avatar
Drives: 2014 GT86
With stock twins ecu tune/stock throttle mapping torque dip is there, i doubt there any games are played regarding that (otherwise i'd expect that to be hacked around/"fixed" by throttle remap in MY2017, as many complained about it in past for twins). But yes, throttle mapping is not linear, and judging by how it's done, imho game that is played in stock tune is to make impression of having larger engine, by actual throttle opening much steeper during first part of pedal travel. That doesn't affect so much how immediate throttle response is though, drawback being less fine low-medium open throttle control to pay for that bigger engine faking.
Still, as i already mentioned above - supercharging might be considered as option. It won't change a bit throttle response, which will same exactly same as in NA. With SC engine should behave same as NA except generating more power, like if engine had been NA but of bigger displacement (at cost of less efficiency due gearing/pumping losses from driven by engine supercharger, instead of more efficient turbocharging that is driven by recuperated energy of exhaust gases).
But imho lag of well done turbo setup that isn't concentrated on max output, but instead on little lag/quick spoolup from low rpms with single turbo optimized for low rpms or twin turbo (STI's setup is not such in my eyes, rather set for max power from engine, mostly at top) can be rather responsive, and you might be trying to avoid such too undeservedly.
Old 07-22-2019, 09:51 AM   #194
Tokay444
There's a really easy way to find out of you're getting the throttle position you think you are. Log it.
For all else, see quoted post.
Old 07-22-2019, 12:16 PM   #195
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
I would 100% sell my turbo kit to fund running an ITB setup. I hope they can utilize Ecutek and get everything figured out. I will be watch this thread closely. Going back to N/A would be ideal for me.
drew_kar is offline   Reply With Quote
Old 07-22-2019, 12:18 PM   #196
Tokay444
Keep your turbo AND run ITB...
The Following User Says Thank You to Tokay444 For This Useful Post:
StraightOuttaCanadaEh (07-22-2019)
In for the long haul Ultimate NA build thread. celek Engine, Exhaust, Transmission 683 06-07-2020 07:26 PM
TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL Andrew666 AUSTRALIA 8 11-19-2018 05:24 AM
RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** RallySport Direct Transmission and Driveline 92 09-01-2015 01:17 PM
RallySport Direct's Ultimate Interior Thread! RallySport Direct Interior Parts (Incl. Lighting) 45 03-25-2015 02:12 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 06:25 PM
