#631 | |
Drives: 2013 MT Asphalt FRS
Do you by any chance know the difference between v1 and v2 template file? |
#632 |
Drives: 2019 BRZ Limited PP
I wanted to wait a week before asking for help, hoping the ECU needed to adjust but something doesn't feel right.
2019 BRZ stock besides a new Corsa cat back exhaust. Every gear feels more sluggish, third gear has drastically less power. I've had a couple friends who own BRZ's drive it, and they feel the same way. Any Idea on what could be happening? |
#633 |
Drives: brz 2017 hksv2
DonneParty, you need to log your car. Log a small drive with low. throttle driving and one WOT pull in third from2k rpm to redline and upload to datazap and put link here or even better in the Data Logs thread
#634 | |
Drives: Toyota GT86
V2 is for the newest tablet (with the bigger screen) Do not mix them, or your screen is going to be unreadable.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#635 | |
I'm trying to get the Overrun pop tune to work but it's highlighted in red I have the B01C definitions Thanks! |
#636 | |
Drives: FT86
Did you get my definition from first pist in this thread ? , Then mske the cakid mod as per instructions in first post The standard oft def has some errors in tabkes people use for pop tunes When ever you male a change in romraider it highlicghts cels in red. Jist make sure the numbers and axis values in the table your changeing are not corrupted or incorrect before you start modifying table see image above for example corruptions, this means your definition is incorrect |
#637 |
Drives: 2020 BRZ tS
Anyone know the difference between the v4.01 and v4.03 tunes?
Can find Release Notes anywhere. |
#638 |
#639 | |
Drives: FT86
Their is a difference between V1 v2 and V4 tu es though Like V2.03 to V4.03 yeah thats different |
| The Following User Says Thank You to steve99 For This Useful Post: | mgarcia707 (07-15-2019) |
#640 |
Drives: 2014 BRZ
Hi all, I upgraded to the 4.03 tune. LC works fine but FFS doesn't seem to work? Is there a particular way I should be driving that's not obvious to me? I just keep my foot down while hitting the clutch and the revs jump (luckily I caught it before over-revving).
#641 | |
It only works above a specific RPM if I recall. If you open it in RR you should see the parameters. BTW, our cars have rev limiters. |
#642 | |
Drives: FT86
FFS is disavled by default in all v4 tunes. You will need to edit tune to activate |
#643 |
Drives: 2014 BRZ
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 07:29 AM |
| The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 04:14 PM |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 02:04 PM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 06:29 PM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
