#365 |
Drives: 2023 BRZ
What is the hottest oil temperature you guys have seen with this dual cooler? A buddy recorded a sustained 257* F with it yesterday.
Director of Rocky Mountain 86CUP
#366 |
Drives: 2015 FRS
#367 | |
2013 Series 10 FRS #553
#368 |
Drives: 2023 BRZ
Stock drivetrain. 100*F ambient. Probably 5W-30 oil.
#369 |
Bit high but nothing to be affraid. Just imagine what temps would be without it. No way you have made it through the session. The ambient temps make a big difference in affecting temps. Track temps were at least 15-20f more I bet.
#370 |
Drives: 2023 BRZ
Yeah, I heard someone saying 135*F +.
I think saying, "No way you have made it through the session" is a bit much. I ran 285 without issues. Other people here have seen 300. The Mobil 1 engineers say it's not an issue. But that's a discussion for other thread, I guess. I'm going to send my 0-20 in for analysis after 8 track days and some high temps. Blackstone is still the one to go to for that, right?
#371 | |
#372 |
Weight Weenie
Drives: 15 FR-S
I’ve ran two track days with this installed now and my oil hasn’t gone above 220F. Yesterday was a hot one, it was 33c ambient temps.
Last year I pulled off track after about 6-7 laps and was always excelling 250F. Currently Using Mobil 1 0W-40 It’s such a pleasure not to have to worry about oil temps. |
#373 |
Drives: 2017 DGM BRZ PP
I've only seen my oil up to 235 F at track days with 20 minute sessions, usually it's stable around 225-230 F. It looks like it's going to be 105 F on Saturday at Thunderhill, so we'll see how it holds up with high ambient temperature. That's going to be brutal...
#374 |
Drives: BRZ 2013
Highest i saw with the cooler on track with forced induction after a 20min session is 250F, running 5-40 oil or 15-40 and it went back down to 212F within about 3 minutes after session was over. Worked very well.
#375 |
Drives: 2014 BRZ Limited, Satin White Pearl
225-230f with 10w40 Redline when pushed on the street. No track days.
I still have the under panel installed as well. All exhaust in engine bay is wrapped. Spal fans wired so both fans come on vs just one when coolant temps rise.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
#376 |
Seeing sustained 240-250F after 5 min on track (5w30 and 20C ambient). Water temp seems to stay ~ 30F lower than oil, so I'm typically 215F. I'd like to have lower coolant temps, but I'm thinking that is the trade off with this style of cooling.
What is everyone else seeing for coolant temps on track? |
#377 | |
Drives: FRS
Time to move the oil cooler rad. ![]() Or, outta daa box thinking - add a Jackson rad oil cooler as well ? Hmmmmmmmmmmmmmm ------ Last edited by RFB; 07-19-2019 at 12:17 PM. Reason: swelink as oosooal ! |
#378 |
Drives: 16' BRZ
More Data
Track event at Blackhawk Farms Raceway, ambient temperature was 93F. Car specs: JR DROC (0W-20 Oil), JDL ceramic coated header, E85, 17x8 wheels, Falken RT615K+'s, Winamx W5 pads. Last edited by FymTom; 08-07-2019 at 04:16 PM. |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler | Jackson Racing | Engine, Exhaust, Bolt-Ons | 0 | 04-25-2016 05:35 PM |
| Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. | OkieSnuffBox | Engine, Exhaust, Bolt-Ons | 5 | 01-12-2016 11:26 AM |
| Jackson Racing Supercharger and JR Oil Cooler | bobsacamenoh | Engine, Exhaust, Bolt-Ons | 20 | 12-12-2014 02:00 AM |
| Jackson Racing oil cooler for NA vs FI | ayau | Engine, Exhaust, Transmission | 1 | 05-29-2014 11:04 AM |
