Drives: Looking to buy
TRD Quickshift AND Short Shifter?
I bought the FT86SF short shifter and was wondering if it would be a good idea to install the TRD quickshifter as well.
Is this a mod where you only should install the one option and not both? Or is it overkill to have both installed? Want to know if anybody else have experience with this combo. Any possible issue that could derive from this? Sent from my GM1915 using Tapatalk |
#2 |
Drives: Bone stock
Subd
Sent from my SM-N960U using Tapatalk |
#3 |
You will shift gears so fast that you will finish before you started. There could be some sort of time vortex created.
I would think it would be over kill since both do the same sort of thing in a different way. There have been a PILE of issues with the quickshifter reported on here and I personally wouldn't touch one. Here are a couple of examples. http://www.google.ca/url?sa=t&rct=j&...paJLm33z5vrn8q http://www.ft86club.com/forums/showthread.php?p=2257744
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#4 | |
Jokes aside. I definitely do not want to have something where I have to glue shut and even then coming off... Im already having problems with the FT86SF short shifter where the rod connecting through the short shifter is not connecting at all.... Contacting the company to see what they can do. Sent from my GM1915 using Tapatalk |
#5 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (07-17-2019) |
#6 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
There was somewhere someone paired the TRD "quickshifter" with a Kartboy shifter but it required more effort. I had the TRD quickshifter and I'd have to tighten the bolt every few weeks or months because it kept coming lose. It was nice when it worked though....
#7 |
Drives: Scion FR-S Series 10 #2462
Beware of the TRD Quickshifter. I had one on my car and the bolt that holds it onto the shift linkage invariably comes loose and leaves you unable to shift into gear. I had locktite on mine and it still came loose. Plenty of posts on this forum about how they are junk. YMMV.
| The Following User Says Thank You to MJones_RB For This Useful Post: | jc7993 (07-17-2019) |
#8 | |
Drives: Whiteout FRS
But honestly, I wouldn't say it's junk right away. It's just a lazier way of making the shifter w/ shorter throws. I think at the end, you can always replace that bolt with a slightly longer one and add a nylock nut (w/ loctite on that as well) to prevent it from backing out. Edit: the only issue you will run into is that it might rub against the driveshaft depending on how much longer the bottom side of the short shifter is prior to the TRD quick shifter adapter. Make sure you do install the bushing that comes with the TRD quick shifter kit as that gives a lot less play when driving compared to stock. |
| The Following User Says Thank You to Bach415 For This Useful Post: | MJones_RB (07-18-2019) |
| 2017+ PP short shifter vs. STI short shifter | teabubblez | Engine, Exhaust, Transmission | 8 | 01-23-2019 11:16 PM |
| FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 09:57 PM |
| cae ultra shifter vs short shifter | jdmblood | Engine, Exhaust, Transmission | 22 | 01-13-2016 11:19 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
| TRD Short Shifter Quick Shifter Scion FRS | hirollaz | Transmission and Driveline | 3 | 04-15-2014 01:24 AM |
