07-10-2019, 04:29 PM | #20973 | |
Drives: 2017 BRZ PP , 2005 Saab 97X
not a pain per se it was painful in that you are cutting holes in your hood. check out my instagram for more photos but Verus gives you outlines you tape to the bottom of your hood. then you drill out some holes for the bolts on the vanes to go through and then some bigger holes to start cutting. i used a dremel with a cutting wheel. some guys use a sawzall or a 4 inch cutting wheel on a grinder. I finished my holes with a counter sink bit and then filed down the edges to a smooth bore and then cleaned up the corners so theyd be covered. the vents are aluminum and will conform to the hood, do NOT bolt down the nuts tightly like less than 10 ft lbs finger tight plus half turn is what i did, you dont want to wrinkle the hood its pretty easy and straightforward its just... theres no going back |
07-10-2019, 04:50 PM | #20974 |
Drives: 2014 Scion FR-S
Most recent is headlight/signal restoration. Florida sun is a killer for a 100% outside car.
The Following 6 Users Say Thank You to MCTeeJ For This Useful Post: | Clutch Dog (07-10-2019), DarkPira7e (07-10-2019), Feistyfrog (07-10-2019), humfrz (07-11-2019), MJones_RB (07-11-2019), wolffbite (07-10-2019) |
07-10-2019, 06:16 PM | #20975 |
Drives: 2013 pearl white FR-S
gonna be putting new brake pads and brake fluid soon... i'm at 44.5k miles currently... should i replace the rotors or they ok with a resurface job?
07-10-2019, 08:12 PM | #20976 |
Drives: 2015 f150 crew cab 4x4 '13 FRSraven
Installed the OEM lookalike armrest. One of my favorite mods so far. Just the right height. Red stitching. Installed in 5 minutes my own way. Cost $130ish
The Following User Says Thank You to Freerider For This Useful Post: | humfrz (07-11-2019) |
07-11-2019, 12:24 AM | #20977 | |
humfrz |
07-11-2019, 12:27 AM | #20978 |
07-11-2019, 11:24 AM | #20979 |
Drives: Firestorm red FRS 2015
Added a Fumoto F-108*valve, pretty cool. Had to tighten it down a bit more then they said I would have to... I had a small leak after I finger tightened it and used a 1/4 turn of the wrench to tighten it. Had to give another 1/4 turn to make it stop.
Sent from my ONEPLUS A6013 using Tapatalk |
07-11-2019, 05:39 PM | #20980 |
Drives: 2017 SUBARU BRZ
Pics of that arm rest FreeRider
"My teacher tells me real beauty is on the inside." "That's just something ugly people say." |
07-11-2019, 10:06 PM | #20981 |
Drives: Red 2014 FR-S
Tinted the windows today. Car had been reading 114° on the thermostat lol. Got sick of being hot on my drives home. Llumar ceramic, 30% up front, 15% in the rear.
The Following User Says Thank You to caballo_glue For This Useful Post: | MJones_RB (07-12-2019) |
07-11-2019, 10:08 PM | #20982 |
07-12-2019, 02:14 AM | #20983 |
Drives: 2018 86 GTS
I dumped the oil out for the 22,500km oil change. I lifted the pan so it was just under the sump plug this time, so didn’t spill a drop.
Then, while waiting for the sump to drain, I realised I’ve forgotten to buy oil to put in. Oh well, time for my semi-annual bus ride. |
The Following 5 Users Say Thank You to suzyj For This Useful Post: | alan.chalkley (07-12-2019), humfrz (07-12-2019), Myriad (07-12-2019), new2subaru (07-12-2019), RToyo86 (07-12-2019) |
07-12-2019, 03:49 AM | #20984 | |
Drives: 4wd zooks
The Following User Says Thank You to alan.chalkley For This Useful Post: | suzyj (07-13-2019) |
07-12-2019, 10:41 AM | #20985 | |
@suzyj - what the hell is wrong you folks from Australia today (or tomorrow or was it yesterday?). humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | alan.chalkley (07-13-2019), suzyj (07-13-2019) |
07-12-2019, 12:15 PM | #20986 |
Drives: 2013 Scion frs
Customized the rear deck today, deleted the 3rd brake light and covered in suede material. Peep the red rear seatbelts too
Sent from my Pixel 3 using Tapatalk |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
