Old 07-02-2019, 04:55 PM   #29
Chuckls
Moutain Runner
Originally Posted by Vatabot View Post
Hi,
I would be interested in the Sparco Terras 17×7,5 ET48 for the winter.
Does someone know if they clear the Brembos of the PP ?
Tirerack will since you buy them from TR.
Chuckls is offline   Reply With Quote
Old 07-02-2019, 05:55 PM   #30
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Evan55 View Post
I think Im going to try Enkei TS-V next. TireRack says they should fit so if not they should take them back.
Oh, TireRack has free returns if wheels that they say will fit actually don't?
Old 07-02-2019, 09:51 PM   #31
Evan55
Drives: 06 Exige, 17 BRZ PP
That is conjecture on my part. I will talk to a rep about it before I order.
Evan55 is offline   Reply With Quote
Old 07-03-2019, 12:19 AM   #32
Vatabot
Drives: GR86 base model Neptune blue
I doubt that Tire Rack will pay for the return from Germany
Vatabot is offline   Reply With Quote
Old 07-03-2019, 01:00 AM   #33
churchx
churchx's Avatar
Drives: 2014 GT86
But tirerack might be used as another information source to check clearance.
churchx is online now   Reply With Quote
Old 07-07-2019, 08:32 PM   #34
MachineHead
Drives: BRZ Limited
anyone know if enkei ts9 18x8.5 +40 will clear? thanks
-Paolo
MachineHead is offline   Reply With Quote
Old 07-07-2019, 09:26 PM   #35
mixxxx
mixxxx's Avatar
TRD forged 17x7.5+43
No spacers required
mixxxx is offline   Reply With Quote
Old 07-08-2019, 04:53 AM   #36
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by canyons View Post
Freshly detailed !
This seems to be 17x8 in the front and 17x9 in the back.
@canyons, am I correct? What offsets are these?
Old 07-08-2019, 08:45 PM   #37
MachineHead
Drives: BRZ Limited
Which wheels clear 17+ BRZ Performance Package Brembos
Enkei
T6S 18x8.0 +45 barely fit, probably need a 3mm+ spacer
TS-5 17x8.0 +45(?) FIT
TS-10 18x8.0 +45 FIT
if enkei t6s 18x8 +45 “fits”, does that mean t6s 18x8.5 +45 will fit too with a bit more clearance?
Old 07-08-2019, 09:03 PM   #38
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Maybe, but the "wider => more clearance" logic doesn't work for RPF1s:
RPF1 17x8.0 +35 FIT (note that they have convex spokes in 8" wide variant)
RPF1 17x9.0 +35 DO NOT FIT (need 8mm spacer, but even then sit too tight)
Old 07-10-2019, 04:22 PM   #39
MachineHead
Drives: BRZ Limited
good point. back to square 1. damn
Old 07-11-2019, 02:57 AM   #40
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
yes that's right. +45 offset on both front and back. All four wheels were less than $1000 delivered. Purchased from Vivid Racing in texas. Very happy with them. Lots of comments at car events. See my separate post on touch-up paint since Enkei won't sell it directly.
I am running a 3mm spacer up front to clear the calipers. Car is mildly lowered on Enkei coil overs. The fronts do not rub ever. The rears occasionally rub on extreme cornering when also fully compressed (i.e. bumps or steep elevation change while cornering. I hear them maybe once a month.)
Currently running MPSS tires size 245/45 at the rear, but this size was discontinued so I'll be going to a 245/35 MPSS or or R888 next...
A recommendation: buy a spare wheel in your size at the same time you buy the primary four; the colors will match better (since they painted at same time) and you can swap one out for repairs if one gets damaged.
canyons is offline   Reply With Quote
Old 07-11-2019, 03:47 AM   #41
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
yes that's right. +45 offset on both front and back. [...]I am running a 3mm spacer up front to clear the calipers. Car is mildly lowered on Enkei coil overs
Oh, just noticed you have non-Brembo calipers, so not directly relevant to this thread. My bad!
However, many folks here might consider using 17x8 in the front and 17x9 in the rear since 17x9s don't fit in the front but they do look much better (common opinion).
Thanks for your reply.
Old 07-13-2019, 07:17 PM   #42
zze133L
Drives: 2019 86 TRD
WedsSport SA10-R 18x9.5 45mm clears the brembo brakes. There's also another user here where the same wheels i have clears the TRD 6/4pot brakes.
You do need coilovers though, the wheels will interfere with the stock suspension. As of this post I have 245/40/18. Debating if i want 265/40 or 265/35.
zze133L is offline   Reply With Quote
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
