#99 | |
Senior Misanthrope
#100 |
@Sleepless would you mind emailing me the data from both? I'd like to compare, as when I've used both units simultaneously with a clear view of the sky, my data has never varied +-0.03
#101 |
Drives: 2016 FR-S
I don’t have the data. This was done at Pacific Raceways which has trees around it so can be GPS-challenging.
After a redo the test I’ll send you the data. I will use different units to help rule out a “bad” Solo 1. Stay tuned...
| The Following User Says Thank You to Sleepless For This Useful Post: | CSG Mike (05-01-2019) |
#102 |
Drives: 2015 FRS
#103 |
Drives: Nevermorange FRS
I'm looking forward to your next test. I have never had an issue with my Solo1 at PR ever, ditto for all the other racers I know that use it as well. Never an issue with GPS either. I suspect there's something else afoot.
PRO86 | WTCC | STL
#105 |
Drives: Many
Can you hard-wire a Solo 2 DL, or must you use the obd2 connector?
If you can hard-wire it, which cable do you use, the obd2 one with the end cut off, or the other CAN cable? |
| The Following User Says Thank You to sfruski For This Useful Post: | ka-t_240 (06-21-2019) |
#106 |
#107 |
Drives: Fr-s
Is there a way to download data but keep it on the AIM device in order to keep the fastest lap (in the case of best lap of day reference).
#108 |
Drives: 2016 FR-S
Had a chance to compare several GPS-based units simultaneously at Pacific Raceways and the Solo and Solo 2 showed very similar results. I also compared to a VBOX Sport.
This testing was done with different Solo/Solo2 units compared to the previous tests I posted. I spoke to the person that did the initial test and learned that the Solo2 came off the mount during a previous session so there is some chance it is not functioning perfectly. Conclusion, there is not difference in GPS performance between Solo/Solo2 (and VBOX Sport).
| The Following User Says Thank You to Sleepless For This Useful Post: | CSG Mike (07-10-2019) |
#109 | |
Download, and uncheck the "delete after download" box. If the on-board memory fills up, oldest data gets overwritten first. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | redlined600 (07-10-2019) |
#110 | |
Drives: Fr-s
Fwiw, my solo 2 dl has worked well so far. Also, user profiles ftw
#111 |
Drives: Toyota GT86
Does anyone know if the aim solo 2 DL can read auto trans temps ?
Thanks |
#112 |
Drives: Toyota GT86
Thanks |
| 2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| First FR-S in Ottawa Solo2 Event | Klinn | CANADA | 0 | 06-12-2012 11:13 AM |
