Old 07-10-2019, 04:29 PM   #20973
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Originally Posted by jflogerzi View Post
How much of a pain was it to install?
not a pain per se
it was painful in that you are cutting holes in your hood. check out my instagram for more photos but Verus gives you outlines you tape to the bottom of your hood. then you drill out some holes for the bolts on the vanes to go through and then some bigger holes to start cutting. i used a dremel with a cutting wheel. some guys use a sawzall or a 4 inch cutting wheel on a grinder.
I finished my holes with a counter sink bit and then filed down the edges to a smooth bore and then cleaned up the corners so theyd be covered.
the vents are aluminum and will conform to the hood, do NOT bolt down the nuts tightly like less than 10 ft lbs finger tight plus half turn is what i did, you dont want to wrinkle the hood
its pretty easy and straightforward its just... theres no going back
Clutch Dog is offline   Reply With Quote
Old 07-10-2019, 04:50 PM   #20974
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Most recent is headlight/signal restoration. Florida sun is a killer for a 100% outside car.
MCTeeJ is offline   Reply With Quote
The Following 6 Users Say Thank You to MCTeeJ For This Useful Post:
Clutch Dog (07-10-2019), DarkPira7e (07-10-2019), Feistyfrog (07-10-2019), humfrz (07-11-2019), MJones_RB (07-11-2019), wolffbite (07-10-2019)
Old 07-10-2019, 06:16 PM   #20975
DarkSideFRS
Drives: 2013 pearl white FR-S
gonna be putting new brake pads and brake fluid soon... i'm at 44.5k miles currently... should i replace the rotors or they ok with a resurface job?
DarkSideFRS is offline   Reply With Quote
Old 07-10-2019, 08:12 PM   #20976
Freerider
Drives: 2015 f150 crew cab 4x4 '13 FRSraven
Installed the OEM lookalike armrest. One of my favorite mods so far. Just the right height. Red stitching. Installed in 5 minutes my own way. Cost $130ish
Freerider is offline   Reply With Quote
The Following User Says Thank You to Freerider For This Useful Post:
humfrz (07-11-2019)
Old 07-11-2019, 12:24 AM   #20977
I reckon that would depend on the condition of the rotors. Personally, I wouldn't replace the rotors if they weren't warped (as felt through the pedal) or deeply grooved (visual inspection) or worn down below spec. (as measured).
Old 07-11-2019, 12:27 AM   #20978
Old 07-11-2019, 11:24 AM   #20979
arrow34
Drives: Firestorm red FRS 2015
Added a Fumoto F-108*valve, pretty cool. Had to tighten it down a bit more then they said I would have to... I had a small leak after I finger tightened it and used a 1/4 turn of the wrench to tighten it. Had to give another 1/4 turn to make it stop.
Sent from my ONEPLUS A6013 using Tapatalk
arrow34 is offline   Reply With Quote
Old 07-11-2019, 05:39 PM   #20980
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
Pics of that arm rest FreeRider
"My teacher tells me real beauty is on the inside." "That's just something ugly people say."
xenarc is offline   Reply With Quote
Old 07-11-2019, 10:06 PM   #20981
caballo_glue
caballo_glue's Avatar
Drives: Red 2014 FR-S
Tinted the windows today. Car had been reading 114° on the thermostat lol. Got sick of being hot on my drives home. Llumar ceramic, 30% up front, 15% in the rear.
caballo_glue is offline   Reply With Quote
The Following User Says Thank You to caballo_glue For This Useful Post:
MJones_RB (07-12-2019)
Old 07-11-2019, 10:08 PM   #20982
caballo_glue
Originally Posted by RToyo86 View Post
In that color, they find me of Lexus rc350 wheels
Those do look nice. I might do this on mine.
Old 07-12-2019, 02:14 AM   #20983
suzyj
Drives: 2018 86 GTS
I dumped the oil out for the 22,500km oil change. I lifted the pan so it was just under the sump plug this time, so didn’t spill a drop.
Then, while waiting for the sump to drain, I realised I’ve forgotten to buy oil to put in.
Oh well, time for my semi-annual bus ride.
suzyj is offline   Reply With Quote
The Following 5 Users Say Thank You to suzyj For This Useful Post:
alan.chalkley (07-12-2019), humfrz (07-12-2019), Myriad (07-12-2019), new2subaru (07-12-2019), RToyo86 (07-12-2019)
Old 07-12-2019, 03:49 AM   #20984
alan.chalkley
Drives: 4wd zooks
LOL, i have done the same and then used my bicycle to go and buy oil.
alan.chalkley is offline   Reply With Quote
The Following User Says Thank You to alan.chalkley For This Useful Post:
suzyj (07-13-2019)
Old 07-12-2019, 10:41 AM   #20985
@suzyj - what the hell is wrong you folks from Australia today (or tomorrow or was it yesterday?).
alan.chalkley (07-13-2019), suzyj (07-13-2019)
Old 07-12-2019, 12:15 PM   #20986
Yuhboy
Yuhboy's Avatar
Drives: 2013 Scion frs
Customized the rear deck today, deleted the 3rd brake light and covered in suede material. Peep the red rear seatbelts too
Sent from my Pixel 3 using Tapatalk
Yuhboy is offline   Reply With Quote
The Following 2 Users Say Thank You to Yuhboy For This Useful Post:
humfrz (07-12-2019), MJones_RB (07-12-2019)
