Old 07-08-2019, 06:39 PM   #1
kev0
Drives: '14
Oil light blinks for 1-2 seconds when coming to a stop/complete stop
2014 Automatic with 75k miles.
Mods:
Sprintex 210 SC
Catless UEL Header
Catless dual resonated front pipe
3" Moto East intake
Moto East tune
Weird situation. My oil indicator blinks slightly when I'm coming to a complete stop. It only happens when I'm coming to a stop. It doesn't happen when I'm idling in park, or during cold starts, ONLY when I'm slowing down to a stop. It goes away as soon as I drive again. Could this be a faulty sensor or is my engine on it's way out? I check the oil and it's still at the correct amount, not losing oil.
Just wondering what you guys might think the problem is before I take it to the mechanic.
kev0 is offline   Reply With Quote
Old 07-08-2019, 06:59 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Are you slowing down from 100MPH with full brake pedal pressure applied?
Are you slowing down from 8MPH with incredibly moderate brake pedal pressure applied?
Have you pulled your oil pan to check the pickup for blockage?
Have you thought about purchasing an oil pressure gauge to see the pressure of the oil in your engine?
kev0 (07-08-2019)
Old 07-08-2019, 07:05 PM   #3
ls1ac
ls1ac's Avatar
with an aftermarket tune the engine might not be dropping rpm slowly. watch the tack to see if the engine is cutting out for a split second.
The Following User Says Thank You to ls1ac For This Useful Post:
kev0 (07-08-2019)
Old 07-08-2019, 07:08 PM   #4
kev0
Drives: '14
Slowing down from about 20 mph with moderate break pressure applied.
Have not thought about pulling out the oil pan as I just changed the oil not too long ago but I guess I'll do that.
Old 07-08-2019, 07:10 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Dam bro. Another issue?
I hope it's just a tune issue.
I would just drive right back to your tuner to get it checked out.
The Following User Says Thank You to Mr.ac For This Useful Post:
kev0 (07-08-2019)
Old 07-08-2019, 07:35 PM   #6
kev0
Drives: '14
Yeah...idk why. Nothing with the oil sensor was touched during the installation.
It also seems like the oil lights come on after the engine gets a bit warmer.
Old 07-08-2019, 08:13 PM   #7
kev0
Drives: '14
https://streamable.com/lu1rm
Here’s a video clip. The RPM’s shoot back up in the end. My foot was on the brake the whole time.
Old 07-08-2019, 08:18 PM   #8
DarkPira7e
DarkPira7e's Avatar
Have you tried coming to a stop in neutral to see if it repeats this behavior, or is limited to only when you're in drive and it forces the RPM to be low? Also, just for fun, what weight oil are you running?
Old 07-08-2019, 09:16 PM   #9
First and foremost:
STOP DRIVING IT UNTIL YOU FIND OUT WHAT IS UP.
It has been shown many times here that the oil pressure idiot light doesn't come on until the oil is at a dangerously low level. To continue driving it when it is even flickering is foolish.
Ultramaroon (07-08-2019), wparsons (07-09-2019)
Old 07-08-2019, 09:48 PM   #10
86TOYO2k17
Drives: 2017 toyota 86
Should not be driving your car until it is 100% fixed and trouble free or you will cause more harm and create more issues.
Your traction control and abs lights are turned on and it didn’t appear you where slamming on the brakes to cause them to turn on so that is another issue, possibly related to oil light possibly not.
Possibly a bad fuse, relay, or sensor could be causing those 3 issues. Maybe a bad ground or he removed a ground and didn’t put back on?
I doubt it but it could have something to do with your brake booster “sapping” crankcase pressure reducing oil pressure. Possibly why factory uses hardline.
Also need to ask, when was last time you changed your oil and filter? Are you sure you are reading the oil level correctly? On a flat surface when engine is cold should go off the lower of the two sides and at the bottom of the U in oil should be just at or barely under the full line.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (07-08-2019)
Old 07-08-2019, 10:01 PM   #11
kev0
Drives: '14
My oil temp still gets to temp (201 f). That should mean that the oil is at least flowing, right?
I would stop driving it but I HAVE to drive it to the mechanic. I live 30 miles from him and he specializes on 86's. Towing would be too expensive.
It MIGHT be a sensor problem. I tried coming to a stop in neutral and the light doesn't come on.. only when I apply brakes.
What are some parts that you guys suspect broke? Oil sensor, oil pump..what else?
Old 07-08-2019, 10:34 PM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
30 miles is well within most insurance towing ranges. mine's 50 miles. but the fact that a towing bill for 30 miles is too expensive speaks volumes of how the car was modified. it simply never should have been mechanically modded.
it is almost impossible to go fast for cheap. and the cheap route is almost always the more expensive route.
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
kch (07-12-2019), kev0 (07-08-2019), Tristor (07-08-2019), wparsons (07-09-2019)
Old 07-08-2019, 10:35 PM   #13
radroach
Drives: car
@kev0 I see that your ABS and TC light is also on. I had a broken ABS sensor once, and it put the car into limp mode- not only could I not rev much over 4000 rpm, any time I tried to come to a complete stop the car would nearly stall itself in this mode, even with the clutch in. I see you are in an AT but I imagine it would exhibit a similar behavior.
Are you experiencing any problems with limp mode?
The Following User Says Thank You to radroach For This Useful Post:
kev0 (07-08-2019)
Old 07-08-2019, 10:42 PM   #14
kev0
Drives: '14
You know what... I've never really thought about insurance. I completely forget about it. I just pay my premiums and forget about it. Totally forgot about roadside assistance and towing perks.
car bogging when coming to stop Qball1754 Engine, Exhaust, Transmission 10 06-06-2019 11:39 AM
beeping when coming to a stop Skin Issues | Warranty | Recalls / TSB 8 07-24-2017 10:06 AM
RPM drops 200 rpm and shakes when coming to a stop spatcha88 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 04-21-2015 07:27 AM
Do you ever feel like an asshole for coming to a complete stop? Ozzman Off-Topic Lounge [WARNING: NO POLITICS] 53 01-20-2014 12:35 AM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
