Old 07-02-2019, 08:18 PM   #15
vladniko86
vladniko86's Avatar
Drives: FRS
Originally Posted by jflogerzi View Post
If the squeal goes away with spraying just a bit of water replace the belt. I dont hear anything out of the norm. Our flat fours sound like tractors at idle and your hearing the typical crickets from the HPFP.
Ok I'll just replace some o rings which are leaking oil, put in the new belt and new wide band O2 sensor and hope that's all the troubles I have with this car. Cause I keep getting a post cat too lean code
vladniko86 is offline   Reply With Quote
Old 07-02-2019, 11:07 PM   #16
jflogerzi
jflogerzi's Avatar
Is it stock or modified? Are you the original owner?
2013 Series 10 FRS #553
Old 07-02-2019, 11:09 PM   #17
vladniko86
vladniko86's Avatar
Drives: FRS
Mostly stock nothing engine wise other than kn filter and mishomoto intake hose. And an exhaust after the front pipe. Person before me was some lady who I assume didn't ride it too hard
Old 07-02-2019, 11:23 PM   #18
jflogerzi
jflogerzi's Avatar
Yup so nothing that would require a tune. So all the items you are replacing seems like you are on the right track.
The Following User Says Thank You to jflogerzi For This Useful Post:
vladniko86 (07-02-2019)
Old 07-02-2019, 11:25 PM   #19
vladniko86
vladniko86's Avatar
Drives: FRS
Yup I was thinking of waiting till I got headers and ecutek but I'll prob put a lot of miles till then and I don't exactly want to trash this engine. Gonna change the rollers too to see if I can reduce the noise
Old 07-03-2019, 12:39 AM   #20
Impureclient
Drives: 2015 FR-S
I listened to the video and also didn't hear anything out of the ordinary.
I recently changed my belt at close to 17k when it prematurely started squealing. I changed the belt and it eventually came back about a week later.
I read online about spraying it with 303 aerospace which I already had since I use it on all my plastic and rubber on the car inside and out on every wash.
I Drenched it with that while running and turned car off to let it dry and the squeal is long gone. It's not a dressing but rather a UV protectant that isn't
greasy like a belt dressing. It is worth a shot and will only further help protect the belt from cracking and aging with no side effects.
Old 07-03-2019, 05:56 AM   #21
ermax
ermax's Avatar
Those gatorback belts are no joke. I replaced my squeaky belt a few times and it would only help for a few days. I finally got a gatorback and it’s been silent for a year. I went to my amazon order history to grab a link and noticed it wasn’t a gatorback threw me off for a bit. Goodyear was bought by Continental and they changed the name of the belt but it was the same gatorback belt. Now it looks like the old stock is sold out so they have replaced it with a normal belt and use the same part number. It looks like there is no way to get a real gatorback anymore.
Old 07-03-2019, 05:57 AM   #22
vladniko86
vladniko86's Avatar
Drives: FRS
Are the new ones just as good or no?
Old 07-03-2019, 06:04 AM   #23
ermax
ermax's Avatar
BRZ Squeal, Belt and Idler pulley question
The Continental version I got was identical to the Goodyear version but if a reorder it today it will be a traditional belt. The description even explains that they are phasing out the gatorback design. It looks like the gatorback is officially dead now.
Here is what I ordered:
Continental OE Technology Series 4060815 6-Rib, 81.5" Multi-V Belt https://www.amazon.com/dp/B001C9A4YA..._w1hhDbBNTQTDX
Same item number but completely different part now.
Edit: Actually this is the item listing that explains the change:
https://www.amazon.com/dp/B000C36BHG..._-9hhDb2K3ZVT8
The Following User Says Thank You to ermax For This Useful Post:
Ultramaroon (07-03-2019)
Old 07-03-2019, 03:08 PM   #24
Hey y'all not to hijack a dead thread or anything I'm having the same sorta sound. Was wondering if y'all could help diagnose. The squeal did go away after spraying water but this just sounds rough for a 55k mile car.
https://share.icloud.com/photos/0Uts...DWlbMH4Qw#Home
It's not rough at all. Perfectly healthy engine. I hear a touch of the cricket for a split second in the third video.
vladniko86 (07-03-2019)
Old 07-03-2019, 03:09 PM   #25
vladniko86
vladniko86's Avatar
Drives: FRS
Oh that's the crickets everyone refers to. Yup I hate them lol. Boxers sound weird huh, just like everyone else told me
Old 07-03-2019, 04:53 PM   #26
Oh that's the crickets everyone refers to. Yup I hate them lol. Boxers sound weird huh, just like everyone else told me.
No worse than any other diesel.
Idler Pulley DIY Guide? shellslinger Engine, Exhaust, Transmission 30 03-18-2021 03:23 PM
NST Crank/ Alternator/ Water pump kit & RACESENG IDLER PULLEY KIT shaynek Engine, Exhaust, Bolt-Ons 1 04-06-2018 05:09 PM
Raceseng Light weight Crank pulley and idler Vincenttam Engine, Exhaust, Bolt-Ons 2 02-05-2017 04:07 AM
*SOLD* Raceseng Idler Pulley Kit Blue Tensioner Anodized FRS BRZ 86 hirollaz Engine, Exhaust, Bolt-Ons 6 11-29-2016 09:19 PM
changing idler pulley from vortech, dust cover? Sniper2606 Forced Induction 0 02-01-2014 04:02 PM
