Old 07-02-2019, 01:12 AM   #8499
kev0
Drives: '14
Well I'm certain there is a leak somewhere. I just can't find it. Performed a smoke test and soapy water test. Found a couple of leaks but we have since fixed it but the problem still persists.. I'm at the point where I'm about to uninstall the kit and reinstall it. Can a leak cause a spark plug to misfire?
kev0 is offline   Reply With Quote
Old 07-02-2019, 01:15 AM   #8500
jflogerzi
jflogerzi's Avatar
Check install. My tune from Moto East was really good out of the box. Did you give Mike your complete list of modified parts?
2013 Series 10 FRS #553
Old 07-02-2019, 01:17 AM   #8501
kev0
Drives: '14
I sure did give Mike a list of all my mods. I'm going to do a tear down of the install again.. I NEED to get this fixed.
Old 07-02-2019, 01:18 AM   #8502
jflogerzi
jflogerzi's Avatar
Be patient and take your time. Its well worth it in the end. Walk away for the night and start fresh in the morning.
The Following User Says Thank You to jflogerzi For This Useful Post:
kev0 (07-02-2019)
Old 07-02-2019, 01:38 AM   #8503
86TOYO2k17
Drives: 2017 toyota 86
A misfire is usually a bad spark plug. However since I’m assuming you had no issues prior and you don’t need to touch those for install I would rule that out.
Then it would most likely either be from a leak someplace. Make sure every single hose has a tight secure hose clamp and or zip tie on both ends and the hose is fully pushed on and seated.
Misfires can also often be caused by dirty, clogged injectors, or the injector seal was damaged/pinched on install, did he use grease on the injector seal when installing to prevent damage like the manual suggests? Or if he did, did he use too much and get some In the injector clogging it. or make sure the injector harness plug fully seated and connected properly.
After resolving any issues/leaks are you clearing all the codes before starting back up and testing it?
Also just to make sure it’s not something super obvious... are your map and maf sensor stock? Are they plugged in? Did you make sure not to pinch and damage the o rings?
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (07-02-2019)
Old 07-02-2019, 01:44 AM   #8504
kev0
Drives: '14
My installer will be doing a full tear down tomorrow to get to the bottom of this. I also did make sure to clear codes before starting back up and testing. All sensors are stock and plugged in. There's no way that the spark plugs/coil packs broke after the install..that would have to be an insane coincidence.. I'm pretty sure it's just a leak somewhere that I cant see.
Old 07-02-2019, 11:09 AM   #8505
toast
Drives: 14 BSP Edelbrock BRZ
A leak will show up as large (20% or so) positive short term fuel trims at idle. Do you have an idle log? If it is very bad they will be maxed (+29%) meaning you are dumping fuel to compensate for the leak and you can dump so much you get misfires.
toast is offline   Reply With Quote
Old 07-02-2019, 05:53 PM   #8506
kev0
Drives: '14
I think I know why my car wasn't starting up. I seem to be missing a hose and a valve from step 5.18 in this manual: https://www.innovatemotorsports.com/...wvMeUjixoZNJM0
Also, does anyone know the differences with kits with part 6010, 6011 than the 6012,6013? I ask this because I was following a different manual during the installation that didn't mention any of the parts from the first manual. This was the manual I followed: https://www.innovatemotorsports.com/...T86_Manual.pdf
My kit is nonintercooled which is why I followed that manual..
For those with the kit installed, do you guys recall doing step 5.18?
Old 07-02-2019, 07:15 PM   #8507
86TOYO2k17
I believe it is 210 intercooled and non intercooled and 335 intercooled and non. But it doesn’t matter.
You should be using sprintex install manual. Innovate stopped supporting this kit long ago. Sprintex has updated the install manual.
Also 5.18 is the brake booster. You just reuse your hard line and add on a longer hose but it needs rerouting, I explained this previously and told you to double check it... take a few pictures of your install and brake booster line.
kev0 (07-02-2019)
Old 07-02-2019, 07:38 PM   #8508
kev0
Drives: '14
Thank you. I was using the Sprintex manual (http://sprintexusa.com/wp-content/up...6_Rev_1.30.pdf) during my install. On page 21 step 17, it specifically says to replace the hard line though?
Old 07-02-2019, 07:46 PM   #8509
kev0
Drives: '14
Also, my installer took everything apart. He believes that it could be an issue with my intake gaskets which is why cylinder 4 isn't firing correctly.
https://imgur.com/a/fH0d4nI
This didn't happen before the SC. Could it be a faulty installation with a leak somewhere in the hoses or are my gaskets done?
Old 07-02-2019, 07:55 PM   #8510
86TOYO2k17
You take the manual brake booster line that should have come with your kit. remove the check valve, install the hard line in place of the check valve and re install brake booster line rerouting it out of the way of the supercharger. I already showed you pictures of this line and how it’s routed. You could have one long soft line but you do not have a long enough hose. So you need to make up a suitable line reusing your hard line and the hoses supplied.
Old 07-02-2019, 07:57 PM   #8511
86TOYO2k17
I’m assuming you mean manifold gasket? It would have been wise to replace those before installing. At least inspecting them for any damage before install.
Old 07-02-2019, 08:16 PM   #8512
kev0
Drives: '14
Yes, manifold gasket. They were new but I guess they got dirtied up during the install. I will need new ones. Do you know where I could pick some up? Or do you know the sizes of them?
My installer believes its the reason why Cyl 4 is misfiring and giving me vacuum leak symptoms. Cyl 4 is the only one that looks like that.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
