View Poll Results: How many 86 owners are planning on getting the Supra?
I'm definitely getting one 32 12.12%
I might get one if they offer a MT 100 37.88%
No, not me. 132 50.00%
Voters: 264. You may not vote on this poll
Old 07-01-2019, 10:18 AM   #1331
JD001
JD001's Avatar
Drives: Subaru BRZ
Evo and Car rated it 4stars. Saving the fifth star for the really "sporty" version GRMN plus...
Old 07-01-2019, 07:05 PM   #1332
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Just ordered my license plate. Apparently you can't have a "V" on NC plates.
Edit:
Plate for my Supra https://imgur.com/gallery/nAXaSok
wrxgoose is offline   Reply With Quote
The Following 3 Users Say Thank You to wrxgoose For This Useful Post:
dhuang (07-02-2019), funwheeldrive (07-02-2019), JD001 (07-02-2019)
Old 07-01-2019, 10:11 PM   #1333
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
But they let you have the Ericsson triple sausage logo on the plate.
krayzie is offline   Reply With Quote
Old 07-02-2019, 02:06 AM   #1334
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
I see what you did there... Clever.
Didn't realize you can use "/" as a license plate character. I'm gonna make sure our VINwiki PL82VIN supports this now.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
The Following User Says Thank You to dhuang For This Useful Post:
wrxgoose (07-06-2019)
Old 07-02-2019, 02:15 AM   #1335
JD001
JD001's Avatar
Drives: Subaru BRZ
Personal plates are so cheap... In the UK, they're crazy money. Does the plate belong to the vehicle or the owner?
In the UK the plate can be transferred from one vehicle to another (at a cost!). And, can be sold on the open market.
The Following User Says Thank You to JD001 For This Useful Post:
wrxgoose (07-02-2019)
Old 07-02-2019, 08:58 AM   #1336
funwheeldrive
Everything is expensive in the UK. Don't you guys pay over $8/gallon?
Old 07-02-2019, 09:28 AM   #1337
JD001
JD001's Avatar
Drives: Subaru BRZ
Yep, $1.70 for a litre of standard unleaded fuel. But the octane levels are higher.
Old 07-02-2019, 10:03 AM   #1338
wrxgoose
WUB WUB
Plate belongs to me. I ordered it for my 86, since I'll get my Supra before the plate arrives.
Old 07-02-2019, 10:41 AM   #1339
...Does the plate belong to the vehicle or the owner?
In the US it varies by state, as the license plate laws are state jurisdiction, not federal. In Georgia, you retain the plate when you sell a vehicle and can transfer it to the new vehicle, or dispose of it.
In some other states, the plate stays with the car when its transferred.
Here's a site that shows it by state.
JD001 (07-02-2019)
Old 07-04-2019, 02:42 PM   #1340
gymratter
Drives: BMW
2020 Supra Documents Added to TIS
https://www.supramkv.com/threads/202...d-to-tis.1915/
https://techinfo.toyota.com/techInfo....toyota.com%2F
  • Full engine model is B58B30M.
  • Power is listed as 335@5000 to 6500, which is interesting. Flat torque curves are common these days, but a flat power curve almost always means it is being limited by the ECU and/or being under stated.
  • Doesn't require premium fuel (87 octane AKI or higher).
  • "Toyota Genuine Motor Oil SN 0W-20 C5 for GR Supra" engine oil is specified, 0W30 is also acceptable.
  • BMW Frostox HT-12 engine coolant is specified.
  • Crank and rods are forged of course.
  • Steering wheel is 373 mm
  • Automatic Gearbox Oil ATF 3+ transmission oil is specified.
  • Exterior mirrors are heated, auto-dumming and have power folding.
  • Canada/US curb weight is listed at 3397 lbs.
  • Mexico curb weight is listed at 3461 lbs.
  • Fuel tank capacity is 52L
  • Canada/US model code: model code: DB43L-ZRLA, Grade: RZ.
  • Mexico model code: DB41L-ZRLW, Grade: RZ.
  • Front brakes: 40/44mm piston size, 348x36mm 2-piece floating rotors
  • Rear brakes: 44mm piston size, 345x24mm 2-piece floating rotors
  • DOT4 brake fluid is specified.
  • Rear differential is a BMW 215LWS model with 3.15:1 final drive.
  • BMW Hypoid Axle Oil G4 is specified for the differential.
  • Heated power seats with a memory system on the driver's seat.
  • A spare tire is not provided, only a repair kit.
  • Front wheel alignment: toe-in: 0.27° +/- 0.20°, camber: -1.63° +/- 0.50° w/o(AVS), -1.75° +/- 0.50° w(AVS), caster: 7.58° +/- 0.50°, steering axis inclination: 17.35°. Toe is adjustable, camber is adjusted by replacing the steering knuckle.
  • Rear wheel alignment: toe-in: 0.23° +/- 0.20°, camber: -1.83° +/- 0.42° w/o(AVS), -2.00° +/- 0.42° w(AVS). Toe is adjustable.
gymratter is offline   Reply With Quote
Old 07-04-2019, 03:26 PM   #1341
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I realize this isn't your words, but I just wanted to comment...
That, or the torque is falling at higher rpms, so horsepower stays flat. There are definitely plenty of engines that use a smaller turbo for faster boost or torque, but that falls more in the high rpms when the turbo is actually more of a restriction.
The 2.0T in the Accord and Type R are a good example of a small turbo versus a larger turbo:
Chief powertrain engineer Terunobu Kunikane told us that a major differentiating part is the Accord’s smaller-diameter turbocharger. While this lowers the relative peak pressure, the Accord’s turbo spools quicker because there’s less inertia. The charged air also hits the turbine vanes at a sharper angle, which increases the amount of force on the vanes, helps provide quicker throttle response, and increases torque at lower revs.
https://www.caranddriver.com/news/a1...-civic-type-r/
Here are some stock dynos of a WRX and STI. Both have a flat spot in horsepower when their torque starts to fall.
https://www.roadandtrack.com/new-car...ru-wrx-vs-sti/
Old 07-06-2019, 08:09 AM   #1342
vh_supra26
Site Moderator
Drives: Supra
Supra vs Z4 Drag Race!!!
https://www.supramkv.com/threads/202...rag-race.1920/
[ame]https://www.youtube.com/watch?v=atNosTtdUaE[/ame]
vh_supra26 is offline   Reply With Quote
The Following User Says Thank You to vh_supra26 For This Useful Post:
Irace86.2.0 (07-06-2019)
Old 07-06-2019, 10:14 AM   #1343
JD001
JD001's Avatar
Drives: Subaru BRZ
Days of balancing the clutch, getting the revs just right and changing gears just banished forever!!
Where's the skill gone?? The Supra "driver" spent more time looking out of side window..
Old 07-06-2019, 02:08 PM   #1344
Irace86.2.0
It’s been gone for a long time. Gearless electric cars will soon replace even the paddle shifters.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
Dadhawk (07-06-2019), gymratter (07-10-2019)
2020 Toyota 86??? Twin-Dragons Scion FR-S / Toyota 86 GT86 General Forum 225 01-02-2019 12:33 PM
Official: Nissan Concept 2020 Vision Gran Turismo revealed, hints future R36 GT-R vh_supra26 Other Vehicles & General Automotive Discussions 42 01-17-2016 02:28 AM
Nissan 2020 vs Toyota FT-1 vs Acura NSX vh_supra26 Other Vehicles & General Automotive Discussions 35 07-08-2014 05:15 PM
Modellista Toyota 86 Revealed quik1987 Scion FR-S / Toyota 86 GT86 General Forum 385 12-04-2011 04:51 PM
Breaking! Toyota FT-86 II revealed? A-Spike Scion FR-S / Toyota 86 GT86 General Forum 40 02-13-2011 06:16 PM
