Old 06-26-2019, 09:13 PM   #1
CSkap21
Reckless5.86
CSkap21's Avatar
Drives: 2013 Scion FRS
Odd noise after installing coilovers and endlinks
So I just finished installing the Perrin end links and Tein street basis Z coilovers. For some reason every time I the slightest bump there’s a bit of a thud and when turning tightly at speeds there’s a loud click sound almost. I feel like it might be coming from the end link hitting the lower control arm. The rears have been fine. Only installed endlinks on the front as well. Anyone who has either of these products came across these problems?
CSkap21 is offline   Reply With Quote
Old 06-26-2019, 11:09 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yes, there is always a problem when people forget to re torque bolts after a few miles when everything settles.
Simple fix. Just re torque all the bolts you had to remove.
People always forget to read the coilover install manual fully.
The Following User Says Thank You to Mr.ac For This Useful Post:
Tristor (06-27-2019)
Old 06-26-2019, 11:29 PM   #3
CSkap21
Reckless5.86
CSkap21's Avatar
I’ll try that tomorrow but it happened as soon as I got them installed and went on a test drive. Happened within the first quarter mile. Hopefully that’ll fix it tomorrow
Old 06-27-2019, 01:20 AM   #4
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
No worries, you are not the first or the last that have the same exact problem after installing coilovers.
You'll just face palm yourself once you find that one bolt that wiggled its self loose.
CSkap21 (06-27-2019)
Old 06-27-2019, 07:57 PM   #5
norcalpb
norcalpb's Avatar
I had horrible noises with my Perrin endlinks.
If tightening the bolts doesn’t help, my next step would be to put the stock endlinks back on and check for noises.
Old 06-27-2019, 08:14 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Same here. They are just noisy.
NoHaveMSG is online now   Reply With Quote
Old 06-28-2019, 08:53 AM   #7
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I had a set of Tein Flex Zs a few years ago. I had a similar noise as well. It ended up being from the top strut nut (21mm?). Just something else to check.
BigTuna is offline   Reply With Quote
OEM Coilovers with top hats and endlinks Swallace113 Brakes, Suspension, Chassis 5 01-20-2018 10:53 PM
Using stick endlinks on lowered coilovers tskaohu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 06-03-2016 01:25 PM
Clunking noise after installing springs JACK 8URT0N Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-28-2015 04:37 PM
WTS BC Coilovers and Endlinks Wilso Canada Classifieds 5 09-21-2014 01:03 PM
Stance Coilovers & Endlinks Khalis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-24-2014 11:44 PM
