#197 |
Weight Weenie
Drives: 15 FR-S
Legit question, would "Joe Average" be able to tell the difference or are these designed for the more experienced drivers?
#198 | |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
You know good food when you taste it without having a clue how it's made or why it tastes so good. You know that a Cayman GTS handles better than that Kia Forte without being Fernando Alonso.
| The Following User Says Thank You to 949 Racing For This Useful Post: | new2subaru (06-21-2019) |
#199 |
No single post, but a few details further back.
#200 |
Drives: 2023 BRZ
Can you provide a range of expected service life between rebuilds on these dampers? I'm under the impression motorsports-level dampers often need to be rebuilt annually to perform as designed. (rough estimate)
Director of Rocky Mountain 86CUP
#201 | |
Service intervals for Xidas
For frequent or only motorsports use, 100hrs is typical. We would not recommend Xidas for extended winter use on salted roads. That destroys everything under the car, including your fancy shocks. Know that even amateur level racers at the national level (winning national championships) will usually rebuild shocks between 20-50hrs. Pro teams rebuild pretty much every race weekend. If a shock begins to leak, makes new noises or loses damping, it should be rebuilt regardless of age. All Xidas have a standard one year warranty. Our authorized service center is Inertia Laboratory in Austin , TX. Typical turnaround for rebuilds is 2-3 days. Contact Inertia for service rates. http://www.inertialaboratory.com/
| The Following User Says Thank You to 949 Racing For This Useful Post: | strat61caster (06-22-2019) |
#202 | |
Weight Weenie
Drives: 15 FR-S
#203 |
Xida Street Spring Pack ride height
This is 140mm front, 145mm rear ride height with 225/45/17. Probably about as low as we will recommend for the Street version. With driver and passenger, handles huge sharp dips at speed with only gentle bottoming, just like OEM. The difference is it's significantly lower than OEM and actually works on track.
Overall ride quality on the Street springs is a bit better than Sachs on BRZ we tested last week. I think folks are going to be really happy with these. Perfect daily driver setup that is just a few turns of the adjuster knobs away from a whole new level of grip and poise on track than OEM.
#204 |
Drives: 2014 GT86
Different folks may want different things. For example i absolutely don't want any lowering below stock twins height, and hate that 95% of coilover aftermarket target lowering crowd. Well, probably it's what sells and i'm simply been outvoted with their wallets, but still ..
| The Following 2 Users Say Thank You to churchx For This Useful Post: | Clutch Dog (06-24-2019), TofuJoe (06-24-2019) |
#205 | |
| The Following User Says Thank You to 949 Racing For This Useful Post: | churchx (06-24-2019) |
#206 | |
Drives: 2017 BRZ PP , 2005 Saab 97X
Im hoping this street package will be perfect for my usage |
#207 | |
Generally speaking, higher spring rates are simply tied to load that the vehicle will see. Whether that's towing hauling in a truck or cornering harder in a passenger car. A low grip OEM tire can only generate so much lateral grip, which limits how much force is trying to make the body roll. This is the RM (Roll Moment). More grip = higher RM. Higher RM means a suspension is more likely to get too far into the bump stops while cornering hard. Touching the bump stops intermittently at peak lateral G on a bumpy track is OK, but just camping on them even in smooth turns causes major handling problems. The stock shocks do this, riding on the bump stops in high G turns when sticky tires are added. So the first question we ask customers when they ask for advice on springs rates for their Xidas, is what tire they are using. Generalizing here but we would suggest running no more than a 225/45/17 280tw tire with our Street spring pack. If you run say, 255/40/17 200tw tires on the Street springs, you will overwhelm the springs even with the dampers set full firm. The dampers (shocks) themselves play a role in handling roll and pitch moments. Valved and dimensioned correctly for the application and you can get away with lower spring rates. 86 Xidas have increased bump travel over OEM so in effect, more useful travel before the bump stops are engaged. Combine that additional bump travel with better low speed (piston speed, not vehicle speed) damping and you gain suppleness over rough pavement. That's where the grip and composure come from.
#208 |
so running in autox with 225' 200tw should opt for your higher stuff. Ill start saving my pennies
#209 |
Definitely. Same shocks, just the Race Spring Pack. Much busier ride but still soaks up everything everywhere. But that sustained 1.5g on "street" tires is all worth the occasional spilled Starbucks.
#210 | |
I do it old fashioned way. munch on coffee beans and drink hot water after |
| Tags |
| 6ul, 949 racing, blub, xida |
| LED Blub Diffuser? | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-07-2016 12:24 PM |
| Project Mu Racing 999 brake pads | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 11-15-2013 03:55 PM |
| Project Kics R40 racing lug nuts | HighbreadEH3 | Wheels and Tires | 0 | 09-03-2013 01:49 PM |
| The Enjuku Racing Project FR-S! | Enjuku Racing | Announcements, Contests, Giveaways | 12 | 07-19-2012 11:54 AM |
