#8472 | |
2013 Series 10 FRS #553
#8473 |
Drives: 2017 toyota 86
You Could, but got to get a phone mount, rely on/use phone battery, connect it every time, probably have smaller more out of sight numbers. Scangauge hook it up and forget, have easy view right below speedometer of any 4 parameter you want. Look at and reset codes as well.
#8474 |
Drives: '13 SWP GT86
I have a oil temp gauge and an AEM wideband sensor with AFR gauge. Maybe not *needed*, but I thought, why not. Always nice to be safe
IG @squareddesign
http://www.squareddesign.se |
#8475 |
Drives: '14
Anyone willing to sell their 75mm pulley?
#8476 |
Drives: '14
Also, I'm a bit confused. I bought the SC kit off someone who had a manual car. I have an automatic so surely I'm missing the following parts:
![]() I know the hoses can be purchased from autozone, but does anyone know the sizes of the hose? As for the vacuum cap, can I get that from autozone as well? What about the hose barb? As of now, I emailed Sprintex for an invoice for those parts, but if you guys know if these parts can be had from autozone, please let me know! Also, anyone know why there are two different manuals for this kit? https://www.innovatemotorsports.com/...T86_Manual.pdf http://sprintexusa.com/wp-content/up...6_Rev_1.30.pdf |
#8477 | |
Because innovate was the USA retailer for sprintex until sprintex decided to just sell themselves. Same thing basically. I’m sure sprintex manual is most up to date. |
#8478 | |
Drives: '14
When you mention the '1 longer hose', I assume it's the 'Brake Booster Re-route hose', right? In that case, I don't have it. I guess I'll have to buy those 3 parts new from Sprintex. |
#8479 |
Drives: '14
I'm willing to buy these parts plus shipping from anyone who has these parts laying around after installing the kit on their manual cars.
![]() If you have a manual transmission, please check your boxes to see if you have these laying around as they are used for automatic transmissions and should be useless to you. I am desperate!! |
#8480 | |
Lay all the hoses out and take a picture and I’ll double check you have it. Otherwise any auto parts store or even amazon will have heater hose or pcv hose you can buy and use. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | kev0 (06-23-2019) |
#8481 |
Quick question for owners. When do you check the oil level on the SC? When it's warm or hot or when it's cold?
#8482 |
Drives: '14
#8483 | |
Brake booster hardline normally runs where part of the supercharger manifold will be so needs moving out of way. I routed it up top with zip ties. The first pic is the one hose you use that your original brake booster hose isn’t long enough for. So I think your fine. If not it’s a generic hose, not that complicated or hard to find. You just need that trans ecu relocation bracket. A shop could probably make something in a pinch it’s just a metal ] bracket with some holes in it. If you can’t get one from sprintex show the pic to your shop and see if they can make a something. |
#8484 | |
Drives: '14
I Appreciate you taking your time to take your own pictures and guiding me. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
