Old 07-18-2012, 12:55 PM   #15
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Staring at 28.1mpg on my MT makes me envy you AT guys... I can't even say "well the AT is garbage"!
eriktherod is offline   Reply With Quote
Old 07-18-2012, 01:15 PM   #16
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
You guys with manuals being able to launch your cars make me envious if that makes you feel better.
Memphis is offline   Reply With Quote
Old 07-18-2012, 01:25 PM   #17
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Why can't you launch your AT? Push in the brake, let off a little bit, rev it up, and let it go.
MVJ1975 is offline   Reply With Quote
Old 07-18-2012, 01:35 PM   #18
Memphis
Memphis's Avatar
It lugs up to speed even with brake tq. I didnt think it was that bad until me and my friend decided to have some fun at the motorsports park.
His car pulls from a stop and gets at least a half to full car length ahead of me before we both plateau and he still pulls slowly on me from there.
If the auto did not lug he still would have beat me which I dont really care about but it would have been a lot closer.
Best time he had (100 degree weather/high humidity) was a 15.5 (with a huge sub box in the back) and mine was a 16.3 (with everything in the trunk removed) Everything in was like a 16.5-7.
I mean the launch of the auto is going to hurt me and anyone else planning to auto x or road course race.
Old 07-18-2012, 01:39 PM   #19
I have no issue doing it. Only thing that took some figuring out (and this has been documented on here, which is where I first saw it) is you have to NOT press the brake all the way down. About 80% to 90% does it, although the car will start to slip.
Press it all the way in, and the car won't rev past around 2K or so. You can most likely thank the lawyers for that.
Old 07-18-2012, 01:43 PM   #20
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
IIRC, it's the result of that whole bogus "unintended acceleration" fiasco that turned out to be "morons pressing the wrong pedal". So, yep, we can thank lawyers. And morons, as usual.
Old 07-18-2012, 02:55 PM   #21
Ocho-Seis
Ocho-Seis's Avatar
Drives: Raven FR-S 6MT
In manual mode? Not on the FR-S, it won't. It'll sit there and ping off the rev limiter all day until you shift it yourself. The only time the car will shift for you in manual mode is downshifting to avoid a stall. IIRC, I think it'll also upshift if the engine starts to overheat, but I haven't run into that situation yet.
Thanks for the insight. as You can tell I have never driven an auto.
Ocho-Seis is offline   Reply With Quote
Old 07-18-2012, 03:11 PM   #22
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Oh, you'd be correct with the vast majority of manual-mode auto transmissions - most of them do upshift automatically at redline. The FR-S is rather atypical in that regard.
Toyota/Subaru put a lot of thought into the AT on this car, and it shows.
Old 07-18-2012, 04:47 PM   #23
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
Whats a good spot to put the indicator when still in break in process? Lots of info in here that I didn't know about
Style is offline   Reply With Quote
Old 07-19-2012, 02:29 AM   #24
hav0c
hav0c's Avatar
Drives: WRB BRZ Limited (AT)
I set mine to 3600 with the beep on. This gives you enough notice (usually) to shift and avoid going over 4k. Setting the 'Fun Zone Light' to 7k after break-in was extremely satisfying.
hav0c is offline   Reply With Quote
Old 07-19-2012, 03:19 AM   #25
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Interesting to see where you guys are setting the shift light at. Mine is currently set on 5900. Not because I drive it THAT hard, but because I use it as a safety measure to make sure I don't rev the engine too hard. Of course "too hard" is totally subjective but the light and beep warning sure comes in handy when you are passing someone and your focus is totally on the road.
Scaldy is offline   Reply With Quote
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
Shift Knobs For your FR-S TWMPerformance Interior Parts (Incl. Lighting) 19 06-03-2012 09:29 AM
Shift Apparel Lexicon101 Other Vehicles & General Automotive Discussions 2 05-02-2010 12:44 AM
