Old 06-21-2019, 03:02 AM   #1
ephemerality
Drives: None currently
Worse gas mileage than usual
Hey guys, got my GT86 about 4 months ago and just started checking the mileage because I felt that I was visiting the gas station a little too often.
I'm getting 8.8 km/litre combined which seems absurd. Everyone I've spoken to IRL gets at least 11-12km/litre.
My car is mostly stock with an aftermarket catback, so I have no idea why it is getting such bad mileage.
I've cleaned the MAFS and changed the engine oil.. Does anyone know what else to check or how to fix it?
ephemerality is offline   Reply With Quote
Old 06-21-2019, 03:16 AM   #2
p1l0t
p1l0t's Avatar
I got a 74 Lincoln Mark IV that gets 10 MILES to the GALLON because MURICA. So you're fine.
Old 06-21-2019, 03:28 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
What are your driving habits?
Checked tire pressure? Is it low?
How are you calculating mpg/kml?
Old 06-21-2019, 03:58 AM   #4
ephemerality
This is driving like a normal person not going past 5000 rpm ever.
Tire pressure is 34 psi checked it last week.
Using the automatic calculator and also calculating litres/trip
Old 06-21-2019, 04:11 AM   #5
p1l0t
p1l0t's Avatar
Who tuned your car after the catback?
Old 06-21-2019, 04:14 AM   #6
ephemerality
So the car was imported to New Zealand from Japan, and has a japanese exhaust. There was a single owner before me who had the car for about 3 months before selling to a dealer. I bought the car and have only swapped out the wheels for forged wheels.
They wouldn't have imported with a tune right?
Old 06-21-2019, 04:22 AM   #7
p1l0t
p1l0t's Avatar
Yeah I would get it tuned just to be safe. You would be amazed what a guy and a few hours on a computer connected to a dyno can smooth out.
Old 06-21-2019, 08:27 AM   #8
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Check for intake/vacuum leaks.
Also, if you have the means of data logging/monitoring, take a look at your fuel trims. This can tell you if it's running rich.
BigTuna is offline   Reply With Quote
Old 06-21-2019, 10:37 AM   #9
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Disagree. Normal people wind it out at every opportunity.
PetrolioBenzina is offline   Reply With Quote
Old 06-21-2019, 10:52 AM   #10
ephemerality
By 'normal' I meant a typical non-86 driver. Only kept it under 5000 for the purposes of testing efficiecny
Old 06-21-2019, 11:44 AM   #11
extrashaky
Drives: 2014 BRZ Limited
You don't need a tune for a cat back.
Old 06-21-2019, 11:51 AM   #12
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I lose about 3mpg in the winter, but spring and summer see pretty decent numbers, even on wide/sticky summer tires. If this is bad (I don't know that math) then it definitely seems odd. Even with aggressive driving and bad traffic, any highway commuting puts me in the 30s. Even spirited back road driving returns in the 30s.
Nevermore is offline   Reply With Quote
Old 06-21-2019, 12:25 PM   #13
PetrolioBenzina
Drives: 17 86
I'm thrilled with 17 mpg.
Old 06-21-2019, 12:29 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It helps to know what you have done with the car... and what tires you have on there.
Going with wider + stickier tires can plunge your gas mileage by 10-15%.
Front Driver Side Clunking - Already checked the usual suspects PandaSPUR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-24-2018 12:01 PM
What colors compliment Ultramarine besides the usual Bronze/Silver/White. Ginger Academy Cosmetic Modification (Interior/Exterior/Lighting) 5 04-08-2016 09:36 PM
Brakes feel 'stiffer' than usual after pumping 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-14-2014 01:57 PM
Stock wheels in different colors? (other than the usual black/gold/bronze) CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 7 04-10-2013 10:03 AM
Business as usual at Scion Canada HQ colHolm Scion FR-S / Toyota 86 GT86 General Forum 5 07-04-2012 09:17 PM
