CANADA Canada
Old 06-18-2019, 05:06 PM   #169
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Originally Posted by GibbsFRS View Post
This is why we experiment and collaborate! Once I'm done fixing my car, I'm going to try a higher ride height and see how it handles. I was planning on upgrading my coilovers at some point, but this may be the case of an S2000 where it has very competent suspension right out of the box.
As good as the S2000 is out of the box, I always thought the FRZ (lack of camber adjustment aside) had decent suspension too. Once camber could be dialed in, I thought the FRZ were every bit as good except down on power to the S2k. I haven't ripped a FRZ hard around TMP but from Patrick Alex's showing (he's on OEM shocks and springs), there still seems to be time left in his run.
Whats the specs on the Teins?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 06-18-2019, 06:28 PM   #170
icybrzzz
Drives: 2015 Scion frz
I am also on stock suspension/power
icybrzzz is offline   Reply With Quote
The Following User Says Thank You to icybrzzz For This Useful Post:
Frost (06-19-2019)
Old 06-19-2019, 01:30 AM   #171
Frost
Frost's Avatar
That's some fine driving there
Old 06-19-2019, 08:30 AM   #172
Tokay444
Heading out tonight on stock dampers, TRD springs and bars, stock power, and new stock size RE-71Rs.
Old 06-19-2019, 10:07 AM   #173
Frost
Frost's Avatar
I like this trend of people staying stock.
Stay Frosty folks.
But I am jealous of everyone throwing on RE71Rs. I cannot afford to do that given how much track time I see
Old 06-19-2019, 10:27 AM   #174
Tokay444
I'd like to get my hands on some Ts dampers. I think they'd pair well with the TRD springs. Current I find low speed damping is underdamped. High speed is great.
Old 06-19-2019, 10:49 PM   #175
icybrzzz
Would love to hear how it went!
Old 06-20-2019, 06:08 PM   #176
Tokay444
Lots of understeer and tire scrubbing up front from about the second lap on in each session.
Got the point by from a half dozen cars that should be a lot quicker, in the likes of Nissan GT-Rs, 996 911 GT-3s, BMW M2s, etc. so I’ll look at that as an absolute win.
Might have some video to post too if it turns out ok. I was having exposure issues and just wanted to drive instead of fucking with a GoPro.
Old 06-20-2019, 09:12 PM   #177
icybrzzz
1:25.11
Hmmmm, what are your alignment specs like? I pretty much only wore half the tire on my car. These tires need much more camber then you can get from the stock setup!
Old 06-21-2019, 08:35 AM   #178
Tokay444
"Stock" alignment.
[ame]http://www.youtube.com/watch?v=h5xu1CSp62c[/ame]
[ame]http://www.youtube.com/watch?v=V5tbi5ST5Bo[/ame]
[ame]http://www.youtube.com/watch?v=s11OP4wod9s[/ame]
Old 06-24-2019, 10:10 AM   #179
wparsons
wparsons's Avatar
It's even worse if the car is lowered since the rear picks up a good amount of camber while the front will still be at ~0*.
flickr
Old 06-24-2019, 12:43 PM   #180
Tokay444
Crash bolts are in my future.
Old 06-24-2019, 01:44 PM   #181
wparsons
wparsons's Avatar
Get the SPC bolts for the bottom holes and put the stock bottom bolts up top, you'll get a lot more camber and it's really easy to adjust on the alignment rack. With the bolts loose it'll go max negative, and can be easily dialed back a little bit if needed to even up the sides or get clearance between tire and spring seat.
With KW V3's (slotted upper holes) I could've had -3.8*, but dialed back a bit. Without the slotting I'd bet you'll still get at least -2.5*.
flickr
Old 06-24-2019, 04:36 PM   #182
Bent42
Bent42's Avatar
Yep the SPC bolts went 2.75 max.
Bent42 is offline   Reply With Quote
The Following User Says Thank You to Bent42 For This Useful Post:
wparsons (06-25-2019)
Fastest Track Times Thread EAGLE5 Tracking / Autocross / HPDE / Drifting 407 04-17-2026 09:06 AM
NZ Track times diss7 NEW ZEALAND 2 03-03-2014 12:42 AM
FI Track Times wrxgoose Forced Induction 0 07-24-2013 02:17 PM
Can too much grip hurt track times? ayau Tracking / Autocross / HPDE / Drifting 53 04-22-2013 10:28 AM
Top Gear (UK) track times GeeTee86 AFRICA 29 02-15-2013 07:04 AM
