#20875 |
I kinda feel like the fumoto cold only get damaged like this if you didn't have a skid plate. Am I wrong?
#20876 |
#20877 | |
TRACKBREAD
WHAT DID YOU DO TO YOUR FRS TODAY?
Does an extractor get all the oil in our cars? The dipstick tube needs to be designed for it. It needs to go all the way to the bottom of the pan, which I don’t think it does. |
#20878 | |
Drives: FR-S 10 Series
In regards to removing all oil is that better/same/worse that removing the drain plug (aside from being very clean/no chance of cross thread or loose/overtightened plugs)? |
#20879 |
Should be pretty much the same. Maybe you'll get very slightly less oil out then if you pull the plug but it's not really gonna matter. Especially considering most cars with oil coolers probably don't get that oil replaced regularly
#20880 |
Famous Potatoes
Drives: '15 ultramarine
I looked at mine and tried to be positive, remind myself of all the good things in my life now, and remind myself again that it is just a car.
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | MJones_RB (06-17-2019), Ultramaroon (06-17-2019) |
#20881 |
Famous Potatoes
| The Following User Says Thank You to Sapphireho For This Useful Post: | Ultramaroon (06-17-2019) |
#20882 | |
Drives: 2018 Ford Mustang EB Premium 6M
Don
Modern warriors saddle iron horses of chrome
| The Following User Says Thank You to Dadillac For This Useful Post: | why? (06-18-2019) |
#20883 | ||
Drives: '13 Scion FR-S & '17 Toyota 86
@ermax It was a weird bump that I hit, and the coilovers that are on my car are a prototype set from a company that asked us to test them out, not sure if that has anything to do with it, but they ride pretty horribly, lol. The valve has been installed for four years prior to this and has been on the car for 80k miles with no issues. It didn't leak at all after the impact. |
#20884 |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | eastendraceshop (06-18-2019) |
#20885 |
Site Moderator
Drives: ichi 86 Project
Anyone felt zenki 86/BRZ steering is lil too heavy? Or while drifting or counter steering, steering get unknown heavy feel to it? Kouki 86/BRZ have resolved the issue by updating the EPS. Good news is, zenki 86/BRZ owner can do the same thing by replacing the EPS w kouki EPS.
![]() Zenki model should have big “G” on it. Kouki model should have “1”... then why is other one have “3” on it? When I google search that part number it said it’s for ‘18 BRZ STI model. Which I’m assuming it’s for tS model (in US, BRZ tS came as ‘18 model). tS or kouki model EPS price was almost same on eBay (+-$5 difference). So thought to test it out if tS model EPS works on zenki model. Answer that question is, yes, it does work. Work itself took about 30mins. Only 3 bolts, 2 screws & 1 nut to get it off, so why took 30mins? EPS is in very awkward area (behind trunk release & light adjusting buttons), so had to go through several wires with twisting my arm & hand to get those bolts off. If you careful and take your time, it’s not that hard. No, I’m not planning to make DIY, cuz it’s easy mod. Test drove after installation and yes, there’s a difference in the steering feel. It’s a lot lighter. I prefer zenki power steering weight, but kouki power steering isn’t bad either. Here’s a vid (if you understand Japanese) |
#20886 |
Wes
so if I want heavier steering, i can switch back to the older model?
Instagram: @gt86ws
#20887 |
Site Moderator
I don’t see why not... but don’t quote me on that, cuz I haven’t tried it
| The Following User Says Thank You to ichitaka05 For This Useful Post: | StraightOuttaCanadaEh (06-20-2019) |
#20888 |
Drives: LS Swapped Scion FRS = 440HP
Installed a 3.73 LSD rear end. Went pretty smooth, only took about 40-45 minutes.
Makes the car much more enjoyable on the street with the t56. ![]()
| The Following User Says Thank You to spitsnaugle For This Useful Post: | RToyo86 (06-22-2019) |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 05:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 07:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 11:19 PM |
