Old 06-14-2019, 03:05 PM   #15
Vital
Drives: 2015 BRZ
Originally Posted by KingJon1991 View Post
TRD springs are like 300 at the dealership
you can get them much cheaper online instead of going through the dealership...
Old 06-14-2019, 03:12 PM   #16
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Tokay444 View Post
Just cut your springs.
omg!
Old 06-15-2019, 10:31 AM   #17
Racecomp Engineering
Also, get some tire shine on there my friend!
- Andrew
Old 06-15-2019, 02:24 PM   #18
maslin
Benz Tech
Drives: 2017 BRZ Premium
- Andrew
Anything you recommend? The stuff we have at the shop works really well, but it’s $$$. All the consumer grade products I’ve tried are too greasy.
Something to keep them black without looking like a Mother’s commercial.
maslin is offline   Reply With Quote
Old 06-15-2019, 02:26 PM   #19
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by maslin View Post
Anything you recommend? The stuff we have at the shop works really, but it’s $$$. All the consumer grade products I’ve tried are too greasy.
Aerospace 303 protectant.
shiumai is offline   Reply With Quote
Old 06-16-2019, 01:37 AM   #20
Captain Curt
Drives: 2015 Scion FR-S Base MT
Please don’t do this!
Captain Curt is offline   Reply With Quote
Old 06-16-2019, 04:00 AM   #21
ZionsWrath
Thanks
ZionsWrath's Avatar
OP, your first mistake was throwing money ay a problem you didn't understand.
I recommend you spend some quality time learning about wheel specifications, tire specifications, wheel alignment, and suspension.
You bought incorrect wheel and tire combination you thought would work. Then you threw good money after bad trying to bandaid it with spacers and it still isn't right.
Asking internet for answer won't work. You have to put in some time and learn what you want, how to achieve bit, and what you are doing.
Good luck.
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
maslin (06-17-2019), timurrrr (06-26-2019)
Old 06-17-2019, 11:20 AM   #22
Tokay444
Do it, do it.
Old 06-18-2019, 05:40 PM   #23
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Originally Posted by BigTuna View Post
Mach V is a good set of springs too. I had them for a while. Loved them. Plus good support @Mach V Dan
Hey, thanks!
--Mach V Dan
Mach V Dan is offline   Reply With Quote
Old 06-19-2019, 09:55 AM   #24
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
Lowering the car should be done before buying new wheels. Those STI wheels have a high offset and are 7.5 in. wide. Not very aggressive IMO. Nothing wrong with spacers as long as they are installed and torqued correctly. All you need is to lower the car a little. I had the Enkei TS10s 18x8 with Eibach spacers 20mm front and 25mm rear along with eibach springs. Here is a pic of my car a few months back.
"My teacher tells me real beauty is on the inside." "That's just something ugly people say."
xenarc is offline   Reply With Quote
Old 06-22-2019, 02:37 PM   #25
Blueprint
Drives: 2015 subaru brz limited
I ordered TRD spring from the dealer it was pretty cheap but they want 1200$ to install them witch is pretty crazy, so i asked a mechanic friend where going to put them on next week il let you guys know how it looks
Blueprint is offline   Reply With Quote
Old 06-22-2019, 06:03 PM   #26
new2subaru
Weight Weenie
Drives: 15 FR-S
That's insane! Good luck on the install. It won't take more than a few hours.
Old 06-22-2019, 09:21 PM   #27
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I've been satisfied with chemical guys VRP.
Dresses up your plastic trim nicely too.
Optimum tire coating lasts months. I'll be trying that next.
Old 06-27-2019, 03:19 PM   #28
kch
Senior Misanthrope
kch's Avatar
Like said above, 303 Aerospace works well enough. If you want a *little bit* more shine without it being greasy, try Ammo Mud. I'm a big fan of the stuff.
gap, spacers, wheel
I screwed up ! Any ideas? 86Ryan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 08-11-2017 09:54 PM
New wheels screwed my fenders Jarred55 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 24 10-15-2016 10:35 PM
well im screwed marine321 Scion FR-S / Toyota 86 GT86 General Forum 59 12-17-2012 10:00 PM
Screwed. Helix Southeast 39 07-22-2012 07:22 PM
I think i screwed myself!!!! WhatOhS*itBar? Scion FR-S / Toyota 86 GT86 General Forum 14 07-04-2012 12:06 AM
