Old 06-12-2019, 02:59 PM   #295
Originally Posted by OwlDance View Post
Now this is hearsay and I have no idea how true it is but the ft86 itself only sold enough to be considered barely a success despite the costs being shared in the joint project. That doesn't bode well for seeing significant RnD IMHO. Everyone loves to talk more power, but I'm not sure there's a terribly huge amount more that can be accomplished with the current platform while keeping costs the same.
Not to steal @Tcoat's mantra but the car sold exactly the number Toyota/Subaru thought it would based on what the built. If anything, they left a few sales on the table in terms of being conservative. If they had built too many you would have seen more advertising, and most likely rebates to try to move them. They also had to have production numbers nailed down for suppliers so they could only increase/decrease production marginally if at all.
Old 06-12-2019, 03:22 PM   #296
But I'm not an engineer, so this is just me throwing my speculations/concerns into the wind.
The eternal struggle
OwlDance (06-12-2019)
Old 06-12-2019, 04:13 PM   #297
Sasquachulator
Pavement Grey
Originally Posted by chipmunk View Post
.... And what's the point of this post, besides the obvious trunk space that everyone already knows about?
A lotus elise/exige is a third car in the garage. It handles like a go kart, low to the ground and has a gem of a motor (That Toyota 2ZZ-GE!). It does have a small trunk and a passenger seat, but its super impractical.....
-Getting in and out is a chore for even a short person (the car is tiny). Its like getting and sitting inside a bathtub through a window opening that is as high as your waist.
-Once inside its got pretty comfortable but thin seats, and hardly any if at all amenities, so everything's exposed.
-Its probably loud as hell inside...but I think the 2ZZ motor makes up for it.
-It has a trunk...that fits stuff....but its not very big.
-depending on how wide you are you are most likely going to be intruding into the passenger shoulder space.
You'd have to compromise a lot to make it work as a daily driver. Occasional fun car? hell yeah. Trying to daily it? hell naw.
Or you could get a BRZ or the like and half nearly the same experience with vastly more comfort, and quite frankly much less money.
With that said i'd love an Exige/Elise with the 2ZZ, not the later ones with the supercharged 1ZZ Hell i'd even look at an Evora if I want something a bit more "exotic'y"
The Following User Says Thank You to Sasquachulator For This Useful Post:
Rampage (06-12-2019)
Old 06-12-2019, 04:17 PM   #298
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The thing that concerns me is if we've reached a current (realistically approachable) maximum for power to displacement to efficiency ratio with the FA engine for NA applications.
This is why an NA FA24 would make a lot of sense. You can make it a bit less high strung while still getting 230hp (95.8hp/l vs 102.5hp/l). This will help with efficiency a bit. Combine that with increased highway mpg by making top gear a bit longer, and we might see very similar fuel economy out of a bored or motor.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
Adam_L (06-12-2019), davesrave (06-13-2019), HachiRokuX (06-12-2019)
Old 06-12-2019, 04:19 PM   #299
HachiRokuX
Drives: 2017 Toyota 86
Subaru Toyota Collab on Next Gen 86 Stopped
Less high strung = lower redline, right? Kinda like how the AP2 S2K’s 2.2l engine’s redline was 700ish rpm lower than the original car while delivering more HP/torque at a lower rpm?
HachiRokuX is offline   Reply With Quote
Old 06-12-2019, 05:12 PM   #300
Yoshoobaroo
TRACKBREAD
It doesn’t HAVE to have a lower redline, it can have lower compression, different valve timing, etc.
Old 06-12-2019, 09:20 PM   #301
And then Toyota can write off those markets where taxes are imposed on engines over two liters.
...I think... I'm going one what I've read here in the past. I pretty much lurk/skim these more speculative threads.
JohnJuan (06-13-2019)
Old 06-12-2019, 09:29 PM   #302
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Does the UK , certain European countries impose extra taxes on engines that are over 2L ? Sorry, I should google that one
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 06-13-2019, 12:47 AM   #303
extrashaky
Drives: 2014 BRZ Limited
And what's the knowledge of everyone's trunk space, besides the obvious post of this point?
Old 06-13-2019, 01:51 AM   #304
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The thing that concerns me is if we've reached a current (realistically approachable) maximum for power to displacement to efficiency ratio with the FA engine for NA applications. The car as is has a really solid blend of fuel efficiency, practicality, size, weight...everything but the power, which is a little lackluster.
I can't see getting much more out of this car's all purpose practicality without slashing its weight further (seems hard to do without using more expensive materials or significant design changes, this car is plenty big yet light for its size) or going FI, which is a whole other rabbit hole of design compromises and money.
I know it's silly for most people to consider MPG and efficiency on a sports car but I don't think anyone would turn their nose from using less gasoline, not to mention the ever more stringent emissions regulations with each passing year.
A lot of this car is of a one off design, so to speak. The manual transmission was designed strictly for this car and power, the engine itself was a joint venture between Subaru and Toyota as a one off (which did lead to DIT and the FA24), there's a lot of RnD they'd have to do to make sure the car can still be called by the same name, without just making an entirely new car to begin with.
In the end, hp/l doesn't really mean much as a performance metric.
There's no such thing as a one-off design any more. Yes, it looks different to us than every other Subaru out there, but to a computer it's quite similar to Subaru's other cars. Im convinced that the design of this car was really a low-risk experiment prepping for the recent Subaru updates. I'm sure Toyota got something out of the exchange on the back end too.
Now what would that mean for a future generation? Well, it means that the model has already been developed and then improved further, so Subaru should be able to crank out a new "design" fairly quickly and inexpensively. Yes, yes, certification is always expensive, but having a model you know works significantly reduces risk on that which results in needing less integration and test time beforehand.
And I am an engineer, but also throwing my speculations into the wind.
The Following 3 Users Say Thank You to Spuds For This Useful Post:
HachiRokuX (06-13-2019), strat61caster (06-17-2019), weederr33 (06-13-2019)
Old 06-13-2019, 02:17 PM   #305
Yoshoobaroo
TRACKBREAD
Exactly. Similarly it should be fairly low risk to take the FA24 and design a new header, an intake manifold with port injectors for it, and spec some hotter cams and positions for it.
A good point was raised about European taxes over 2 liters. Maybe we’ll get 2 engines like the Miata? Maybe they’ll say that’s tough Europe? Maybe they’ll squeeze the 2.0L for even more than 102.5hp/l? Maybe a mild hybrid setup for torque?
Old 06-13-2019, 02:51 PM   #306
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
They can't squeeze more the existing 2.0L engine. We couldn't even get the updated intake & exhaust manifold!
I wouldn't expect much more power in a 2.4L either. Probably 220-225bhp and a much better torque in mid rev range which is what most people love ...
Old 06-13-2019, 04:49 PM   #307
juniorrr
Drives: Scion Frs
Yeah thats not true.... Toyota Debunked this.
https://www.carscoops.com/2019/01/to...ll-axed-range/
juniorrr is offline   Reply With Quote
Old 06-13-2019, 05:11 PM   #308
funwheeldrive
"We will go out on a limb here and say that the 86 will get a successor, but it might not be co-developed with Subaru this time around. "
The Following User Says Thank You to funwheeldrive For This Useful Post:
Tokay444 (06-14-2019)
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
Supra (Toyota/BMW) vs. FT86 (Toyota/Subaru) GrantedTaken BRZ First-Gen (2012+) — General Topics 150 01-29-2019 02:19 PM
STI ~ Subaru | TRD ~ Toyota | JDM Lanyards & Toyota Emblem Overlay for Scion FR-S! KI_ZN6 Groupbuys 173 01-15-2016 01:56 PM
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 08:55 PM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
