Drives: 2014 BRZ Limited, Satin White Pearl
Valve spring compressor
Anyone have a recommended valve spring compressor for the fa20?
Im going to replace my valve stem seals. Currently have Ferrea 6000 +1mm valves. I've done them before on other engines, just need a good recommendation for a tool that works well on the fa20. Thanks! |
#2 |
I'd get the tools they use for the recall. They're pretty sweet.
#3 |
Drives: 2013 frs red
Are the heads coming off? If not, the factory tool, as ultramaroon says, is nice.
#4 |
I figure head goes face down with a little piece of cardboard under the dome. Still better than those vice-grip things.
#5 |
| The Following User Says Thank You to Tonrogs For This Useful Post: | Lantanafrs2 (06-11-2019) |
#6 |
#7 |
Benz Tech
Drives: 2017 BRZ Premium
The c clamps are a pain. My favorite tool to use was a GM special tool, 2 towers with a bar across and a lever to press down. 5 minutes and they’re all off.
Can’t find a picture of the actual tool, the towers were really nice milled aluminum. Plenty of aftermarket sets out there that look the same.
| The Following 4 Users Say Thank You to maslin For This Useful Post: |
#8 | |
| A simpler spring/strut install DIY -- no compressor needed | jeebus | DIY (Do-It-Yourself) Guides | 120 | 01-17-2023 09:28 AM |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
