Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: 2016 brz limited
Brz rear shaking
When turning from a dead stop left for right the rear end shakes a little until i speed up or straiten it out is that normal for the rear differential ? It’s got about 26k miles on it. 2016
#2 |
ProCrastinationConsultant
possible bent wheel? do you see any scoring/curbing on the wheels at all? could also be loose lug nuts as well.
#3 |
#4 |
I’ve read this is normal for a Torsen diff
#5 |
try rotating the wheels front to back-- if the problem follows, it would be a wheel/tire issue. last possibility could be a bent hub-- that's easiest to check the rear of the car up in the air ferris bueller style, while idling in first gear, and watching the wheels at a specific point for deviation.
#6 |
http://www.ft86club.com/forums/showthread.php?t=45641 according to this it is normal
#7 |
It has done it ever sense I bought it new so it must be okay right ?
Rear shaking | brzboy | Engine, Exhaust, Transmission | 16 | 06-11-2019 09:56 AM |
scion frs 16 shaking. help! | Kana | Issues | Warranty | Recalls / TSB | 20 | 10-16-2016 03:23 PM |
Rear end shaking under acceleration | enjoyminutemaid | Issues | Warranty | Recalls / TSB | 23 | 06-18-2016 05:15 PM |
Shifter Shaking | moe_5 | Issues | Warranty | Recalls / TSB | 5 | 12-07-2013 12:46 PM |
shaking of car | Adam86 | AFRICA | 3 | 05-17-2013 08:42 AM |
