Old 05-16-2019, 11:34 PM   #85
steve99
Drives: FT86
Originally Posted by Kodename47 View Post
Anyone else noticed that the pedal dance has arrived?
Yes sure did , in lastest update
Old 05-17-2019, 12:13 AM   #86
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Peddle dance has arrived?
What do you mean?
I have the latest update I think but you mean traction control off option?
Celigts is offline   Reply With Quote
Old 05-17-2019, 09:42 AM   #87
Fred E
Drives: WRB BRZ
What do you mean?
Yes, the traction control toggle that you see in the app now actually simulates the pedal dance. Traction control, VSC, ABS, and EBD are all off when toggled. The in-car traction control button only turns off the first two.
Fred E is offline   Reply With Quote
The Following User Says Thank You to Fred E For This Useful Post:
Celigts (05-17-2019)
Old 05-17-2019, 09:48 AM   #88
tomm.brz
Drives: brz 2017 hksv2
i do not understand why it toggles also a abs light in the dash, normally pedal dance only disable e-diff and not abs
Old 05-17-2019, 11:49 PM   #89
Celigts
Celigts's Avatar
I have traction control light plus abs light on right now .. but I think ifs for other reasons ...
Widebody ... big ass tires ... or some unknown speed sensor issue. The world may never know.
Old 06-08-2019, 02:59 PM   #90
ML
ML's Avatar
Drives: 13 White MT FR-S
Do you need a license to use the pedal dance feature with this?
The Following User Says Thank You to ML For This Useful Post:
Celigts (06-09-2019)
Old 06-09-2019, 11:16 PM   #91
Celigts
Celigts's Avatar
A license?
You can do the peddle dance whenever u want ... it's an annoying process ... and messes up 90% of the time...
Old 06-10-2019, 12:25 PM   #92
toast
Drives: 14 BSP Edelbrock BRZ
There are 2 different bluetooth modules available online that I see. One is bluetooth+proECU for ~$375 and one that is just bluetooth for ~$210. If I have the old cable/dongle setup for programming I can get the cheaper one and still have access to everything but flashing, correct?
toast is offline   Reply With Quote
Old 06-10-2019, 12:36 PM   #93
tomm.brz
you can also flash
just neee the old dongle that you have with the old. cable
Old 06-13-2019, 12:47 PM   #94
toast
So I got the bluetooth module. First thing it did was install updates. The button I see for Traction Control only seems to turn of the regular traction control, not the pedal dance (only traction light is lit, not vsc). Other people see something different?
Old 06-13-2019, 01:36 PM   #95
tomm.brz
vsc should not light, trc light is good
Old 06-14-2019, 04:57 PM   #96
toast
Could someone create a blank dashboard template and attach it on here? I have a Pixel 3 XL and the default dashboard adds two buttons at the bottom that are half off the screen and I can't grab them to move or delete them because they are behind the shaded area for adding or removing widgets.
Old 07-24-2019, 09:27 PM   #97
thinkV
Drives: BRZ Turbo
Does anybody know if it's possible to add or show peak values? Eg peak boost?
thinkV is offline   Reply With Quote
Old 07-25-2019, 04:38 AM   #98
Mr_Eyo
Drives: 2017 Toyota 86
Mine turned everything off including ABS.
Mr_Eyo is offline   Reply With Quote
Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM DeliciousTuning Software Tuning 331 06-17-2025 03:36 PM
My Bluetooth in my 2014 FRS so stay connect Case1010 Electronics | Audio | NAV | Infotainment 3 02-24-2016 07:57 PM
Header/overpipe interface misooscar Engine, Exhaust, Transmission 4 11-23-2014 12:21 AM
Garmin GPS Bluetooth Won't Connect frssfo Electronics | Audio | NAV | Infotainment 0 08-20-2014 11:55 PM
Bluetooth connect mutes android NAV Rob_g Electronics | Audio | NAV | Infotainment 6 07-04-2012 05:38 PM
