Old 06-08-2019, 02:40 PM   #56939
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
It sure is nice that the twins come with a 10 gallon windshield washer fluid reservoir.
And what prompted this sudden thankfulness?
Spuds is offline
humfrz (06-08-2019), ScoobsMcGee (06-08-2019)
Old 06-08-2019, 03:00 PM   #56940
Cole
Not a troll
Cole's Avatar
For those who asked, I'm totally fine, it was a fairly low speed collision. The guy was going maybe 15kmh at the most, probably closer to 10 though.
Bumper is done, I pushed the dent out, but it cracked up near where the trunk closes. So, going to get the insurance ball rolling tonight and see what the deal is. I'm going to see if whatever body shop who ends up doing it can also repaint my front right fender as well on the cheap since they'll be doing the work and mixing paint anyways.
Cole is offline
The Following User Says Thank You to Cole For This Useful Post:
humfrz (06-08-2019)
Old 06-08-2019, 03:11 PM   #56941
Semi gave me a love tap hit & run a few years back. I just let it go. It's not obvious and I figure getting it fixed would just be tempting fate.
Ultramaroon is offline
Old 06-08-2019, 03:15 PM   #56942
It is going to hit 100° here Sunday and monday. Perfect weather to be loading a Pod.
Surely your son has some young, strong friends you could hire to do that, while you sit back, sip iced tea and supervise -
Don't be overdoing there, old man -
humfrz is offline
Old 06-08-2019, 03:42 PM   #56943
JD001
JD001's Avatar
Drives: Subaru BRZ
FFS! Where's Buddy when you need him??
JD001 is offline
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (06-08-2019)
Old 06-08-2019, 03:50 PM   #56944
I have found that your "buddies" are never available on moving day - however, they always seem to find the time to attend the housewarming party -
humfrz is offline
JD001 (06-08-2019)
Old 06-08-2019, 03:55 PM   #56945
JD001
JD001's Avatar
Drives: Subaru BRZ
Are you talking about "your" or 'my' buddies??
JD001 is offline
humfrz (06-08-2019)
Old 06-08-2019, 03:56 PM   #56946
Glad you are OK.
Are you SURE that that rear end tap didn't push your car's right front fender into that sign along side the road ??-
humfrz is offline
Old 06-08-2019, 04:00 PM   #56947
Don't be messen wich ma grammar - it's Saturday -
humfrz is offline
JD001 (06-08-2019)
Old 06-08-2019, 04:16 PM   #56948
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm having a frustrating Saturday.. dropped the car at dealer for valve works.. garage drop a hint that they can change clutch at the same time. I'm thinking of buying Exedy or TRD uprated clutch/flywheel kit and now looking at engine mounts!! Getting expensive!! But frustratingly, I am out of the country one or possibly 2 weeks, sourcing parts, buying them gets more difficult!
And, the shops are closed today... window of opportunity closing!!!
JD001 is offline
humfrz (06-08-2019)
Old 06-08-2019, 04:23 PM   #56949
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Lifetime supply.
Sapphireho is offline
Old 06-08-2019, 04:43 PM   #56950
Spuds
The Dictater
Spuds's Avatar
Sometimes you just have to recognize a lost cause. Is it worth the time and frustration?
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
JD001 (06-09-2019)
Old 06-08-2019, 05:24 PM   #56951
Hey, hot rod, their ain't nutten wrong with the OEM clutch and pressure plate for average driving. If you have messed up your clutch, by driving on the wrong side of the road, I suggest you have them just replace the clutch and pressure plate with OEM. Their is a good chance the flywheel is OK, they might want to sand it down a bit -
Don't forget the updated TOB!
Out of the country? Where you off to, the French Riviera? After all, it has been a long, damp winter, you deserve a break -
humfrz is offline
JD001 (06-09-2019)
Old 06-08-2019, 05:56 PM   #56952
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
I try to remain a generally appreciative person. Also having to fill it for the second or third time in the nearly five years I've owned the car.
ScoobsMcGee is offline
The Following 2 Users Say Thank You to ScoobsMcGee For This Useful Post:
Spuds (06-09-2019), Ultramaroon (06-08-2019)
