Drives: Scion Frs
Ikonmotorsports Widebody?
I’m currently looking at widebody kits and I was wondering if anyone has had any experience with the Ikonmotorsports widebody? I’ve seen on YouTube 2 ppl run it and the fitment is actually very very decent. But I was wondering if anyone else has had any experience with it first hand and would recommend the body kit or not?
#2 |
LMGTFY
Drives: 13 FRS, 91 Miata
inb4 lmgtfy
#3 |
Drives: 2013 Raven Frs
I just recently put on the ikonmotorsports rb v1 style kit on mine and the fitment is honestly not that bad. There is some fitment issues near the gas cap and the rear fenders in the sense that they are not completely flush. The fitment issue is really small though, you cannot really notice it. Obviously, if you do go with the original rb v1, there will be less fitment issues and it will be out of fiberglass rather than abs.
| The Following User Says Thank You to .Abraham For This Useful Post: | juniorrr (06-05-2019) |
#4 | |
Drives: Scion Frs
#5 |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
doing it properly will have to require fiberglass since you really can't "build" abs. So after trimming to make the kit fit, i'm not sure what other routes you can take besides bondo.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
#6 |
I got mine installed by a guy, he has a channel on youtube called Jonny the Car Doctor. He said he didn't struggle much to install it, but that there was that issue of it not fitting completely flush since it is a rep kit. The tabs on the kit can be trimmed off for a better fit if needed. The fitment issues are very minimal though, and not very noticeable. So far its held up no problems against weather and it gets to 100 degrees here. As for the installation process, look at past posts in the forums or on youtube, it does require cutting the front and rear fenders.
| The Following User Says Thank You to .Abraham For This Useful Post: | juniorrr (06-06-2019) |
#7 |
Drives: Subaru BRZ
Boring... Boring... Boring... Yawn... Boring... Boring.. where are the fucking photographs???
#8 |
Drives: 2013 Ultramarine FR-S
Biggest issues with the Ikon kit being they don't sit flush against the door body line, which is a pretty big give away they aren't real, and the bolt locations aren't really defined like the real kit. Both of my rear flares have cracks forming on one of the center bolt locations. You can also tell it's a knockoff by looking at the edges as they are more rounded instead of squared off.
You can see the door line, and 3rd from the back is the one that is cracking on mine (both sides)
#9 | |
Drives: Scion Frs
#10 | |
Drives: Scion Frs
#11 | |
I had quite a bit of cutting/shaving. Shaving around the gas door to allow it to open without hitting. Cutting tabs off the rear flares so they would fit correctly, and sanding to make sure tires wouldn't rub.
#12 |
Drives: Scion Frs
Hey i forgot to ask you what was your Wheel / tire spec and offset? and spacers if you used any
| IkonMotorsports RB V3 Rep Wing | HachiRo | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 07-30-2016 04:56 PM |
| Greddy widebody v1 help!! | Celigts | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 03-07-2015 02:55 AM |
| LUX Motion widebody kit! | Lux Motion | Exterior Parts - The Rest | 95 | 01-26-2014 11:43 AM |
| 86-R Widebody Kit | C130NAV | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 12-10-2013 09:34 PM |
| Looking for a widebody kit | djliquidsteele | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-28-2013 01:25 PM |
