Old 06-05-2019, 11:52 PM   #1
How I support the engine with a tie-down strap when removing the transmission
A few things to keep in mind.
  1. Don't go cranking it tight right off the bat.
  2. Make sure the right-side hook isn't tweaking the hard line under the cover.
  3. Be careful to route the left side exactly as shown.
  4. It's quite possible to bend the strut braces. Don't be a knucklehead.
Click on the image for full size.
The Following 7 Users Say Thank You to Ultramaroon For This Useful Post:
bcj (06-06-2019), BigTuna (06-06-2019), H1C (06-06-2019), HaXx (02-21-2020), humfrz (06-06-2019), korhun (02-21-2020), Spuds (11-07-2022)
Old 06-06-2019, 12:03 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
How often does this really need to be done?
Old 06-06-2019, 12:08 AM   #3
Whenever the transmission is removed. Guess I should've explained that.
soundman98 (06-06-2019)
Old 06-06-2019, 12:22 AM   #4
soundman98
soundman98's Avatar
I just assumed it was an ancient engine yoga technique that allowed for better oil flow.
Old 06-06-2019, 12:33 AM   #5
It balances the engine's chi.
HaXx (02-21-2020), soundman98 (06-06-2019)
Old 06-06-2019, 03:08 PM   #6
H1C
Drives: 2014 FR-S MT
Thanks for the pics. The routing underneath: is it pretty much straight down the sides and then across the oil pan?
H1C is offline   Reply With Quote
Old 06-06-2019, 03:24 PM   #7
Nope. Look for the hooks. You'll slap your forehead when you see it.
Old 06-06-2019, 03:55 PM   #8
H1C
Oh ok -- it looks like you're hooking onto the two black stamped steel covers on either side of the intake manifold.
Old 06-06-2019, 04:00 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That looks way more convenient the using a jack.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
H1C (06-06-2019), Ultramaroon (06-06-2019)
Old 06-06-2019, 06:29 PM   #10
Now you got it.
Old 06-06-2019, 09:20 PM   #11
H1C
Now you got it.
I like this method -- went outside and checked out those steel covers; yes they do seem sturdy enough to hold the engine still via the tie down. Set it once and forget it for the duration of the job.
With a jack, it's in the way as you're working and moving back and forth to and from under the car; it's too easy to bump it out of place; and as I learned, also pretty easy to jack it back up too much when replacing a jack that's been bumped out of place.
Old 06-06-2019, 09:33 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
...........or when the jack that is supporting the engine is twisted and you can't get the trans jack forward enough to stab the trans into place. Ask me how I know about that one
korhun (02-21-2020)
Old 06-06-2019, 10:04 PM   #13
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Been there, done that. I feel your pain.
The Following User Says Thank You to Mr.ac For This Useful Post:
korhun (02-21-2020)
Old 06-06-2019, 10:20 PM   #14
H1C
Lol yeah... pulling and replacing the tranny to change the TOB has to be the most unpleasant job I've done on this car.
I dented my oil pan by over-jacking the engine after the jack got bumped out of place, and wound up having to replace that. Spent hours trying to cut through the FIPG holding it on. I gave up at one point. Then I got this tool and once it arrived, I was able to cut through the FIPG in a few minutes: https://www.amazon.com/gp/product/B011DR95WM/
And then I had costochondritis for a couple of weeks afterward, from wrestling with a 86 lb hunk of metal for hours, on my back, with about 18 inches of vertical space to move around. Not fun.
But, if I have to do it again to fix my small oil leak coming from somewhere in the bell housing, I'll be using this method to keep the engine from tilting forward.
The Following User Says Thank You to H1C For This Useful Post:
NoHaveMSG (06-07-2019)
Tamara tow strap Dreyup Cosmetic Modification (Interior/Exterior/Lighting) 13 07-09-2017 04:03 PM
Takata tow strap Thatguyjeremy Cosmetic Modification (Interior/Exterior/Lighting) 13 05-20-2015 09:25 AM
FS: Takata Tow strap Tengu Exterior Parts (Aero, Lighting, Etc.) 1 02-26-2014 08:36 AM
rear tow strap karma003 Cosmetic Modification (Interior/Exterior/Lighting) 0 07-23-2013 09:00 PM
Help me strap down my tires qoncept Tracking / Autocross / HPDE / Drifting 5 06-20-2013 04:06 PM
