Old 02-05-2018, 06:12 PM   #15
ermax
ermax's Avatar
Originally Posted by catsspat View Post
Wait, so you have different front/rear bulbs? If so, your math is right. You can also just use (front+rear)/2 for the wattage. However, what do you mean by whatever-watts "when flashing?" Flashing means nothing to this equation. All you care about is the bulb wattage when it's ON.
Well they are switch backs and pull 3w when just the parking lights are on and when they are flashing they switch from white to yellow and draw 4w. But I never measured those myself. I’m just trusting the specs on the amazon listing.
Old 02-05-2018, 07:12 PM   #16
catsspat
Drives: 2013 BRZ Premium MT
You NEVER trust seller claims on bulb wattage.
Based on the fact that you needed much higher value resistors, those bulbs must be drawing far less than 4 watts.
catsspat is offline   Reply With Quote
Old 02-05-2018, 07:42 PM   #17
ermax
ermax's Avatar
Yeah that is my thinking. I ordered the fronts and a relay that omits the burnt bulb notification. But it has this annoying lag when first turning on the blinkers. Then I came across a review on Amazon were someone said they modified their OEM relay so then I found this thread. Before I selected a resistor I ordered bulbs for the rear from the same company that made the front bulbs. When those came in I tested their draw myself and it matched the specs they had on the listing so I figured the specs on the fronts didn’t need to be verified.
Eventually I will pull them out and check them myself and then get a smaller resistor so the burnt bulb detection will work again.
Old 05-28-2019, 08:55 AM   #18
csol
In the same boat. No idea what resistor to use.
csol is offline   Reply With Quote
Old 05-28-2019, 06:41 PM   #19
soundman98
ProCrastinationConsultant
soundman98's Avatar
don't, just order either an 'led flasher' off ebay/amazon/whatever, or buy a tapturn. the newest iterations of tapturn don't have the issue described.
Old 05-29-2019, 05:33 PM   #20
csol
I got a spare blinker module so I'm going to try it first.
Will a 0.22 ohm resistor work
Old 05-29-2019, 07:33 PM   #21
ermax
ermax's Avatar
The proper (and I mean PROPER) turn signal flasher mod for LED bulbs.
It all depends on the draw from the LEDs. This thread has all the info you need to do the number crunching.
Old 05-30-2019, 07:04 PM   #22
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've done this a few times to get the resistance right for various bulbs. Just but a pack of resistors and parallel them if required.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-02-2019, 06:12 PM   #23
csol
I can't exactly pull off bumper and test load easily so i went for trial and error method.
I tried 0.22ohm (caused only one blink and thats it)
0.44ohm (same result)
0.1ohm (fixed blinkers except now hazards are only one blink and then silent)
I ordered a Tapturn module so I'll probably use this temp fix until that comes.
Old 06-03-2019, 01:45 PM   #24
Kodename47
Kodename47's Avatar
Drives: UK GT86
Means 0.1 is still too much.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-03-2019, 07:03 PM   #25
csol
might as well put a wire from 1 terminal to the other? 0.1 is so low
Old 06-04-2019, 09:26 AM   #26
catsspat
Exactly. The over-current protection is kicking in.
Remember, the original resistor meant for 21W incandescent bulbs is 0.02-ohms. So if the LEDs are high power (or the bulbs have extra resistors built-in to just burn up power), the resistor values may need to get quite low to match them.
Old 06-26-2019, 03:03 AM   #27
csol
Yeah I'll probably try just a straight wire after my tapturn module arrives
WTB: Reverse white bulbs + clear switchback front turn signal bulbs Xplicit Canada Classifieds 9 06-12-2016 11:47 AM
FS: JDM TRD Winker Turn Signal Bulbs Eric_FRS Exterior Parts (Aero, Lighting, Etc.) 4 02-16-2016 07:02 PM
FS: OEM side markers + bulbs. OEM turn signal bulbs. akiranakayama Exterior Parts (Aero, Lighting, Etc.) 3 07-29-2015 12:25 PM
Making turn signal your DRL with Flashback LED bulbs coachzizi Cosmetic Modification (Interior/Exterior/Lighting) 9 01-10-2014 09:54 PM
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
